subie22 Posted August 23, 2011 Share Posted August 23, 2011 alright so i have a 2005 legacy gt, stock. I want something that will add some power, with a nice purr. nothing too loud, im not trying to be a cop attraction. Id like for it to be on the lower side of expenses but if you could let me know about some that would be great, thanks Link to comment Share on other sites More sharing options...
scoobydoobie Posted August 23, 2011 Share Posted August 23, 2011 Borla SPT Bosal Or just do axlebacks. Link to comment Share on other sites More sharing options...
BigBlack-V Posted August 23, 2011 Share Posted August 23, 2011 I have an SPT V2 and it sounds nice, its not too loud and has a nice rumble but i also have a catted downpipe I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
SpecBGuy Posted August 23, 2011 Share Posted August 23, 2011 spt or invidia are pretty quiet Link to comment Share on other sites More sharing options...
iNVAR Posted August 24, 2011 Share Posted August 24, 2011 You will not add any power from putting in a CBE. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2011 Share Posted August 24, 2011 You have a 05, you'll want a catless up pipe and a down pipe. I have kept the stock exhaust from there back. The car has a nice rumble to it. You can hear the turbo spool better with a big Dp. You'll need to get the ecu retuned for the new pipes. That's where the power comes from. If you want a different sound you can buy the exhaust later. But I'm happy with my set up running a stage 2 tune. You may also need a 2.2k ohm resistor if you don't have the egt sensor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
IMPORTIMAGE Posted August 24, 2011 Share Posted August 24, 2011 this one sounds nice too http://legacygt.com/forums/showthread.php?t=167030 1-941-257-9618 http://www.importimageracing.com Link to comment Share on other sites More sharing options...
