whiskywizard Posted August 22, 2011 Share Posted August 22, 2011 I've searched here but didn't find anything similar... Could use some advice. I'm intermittently losing power to the stereo and climate controls. I'll be driving and the radio and A/C displays will go blank. Sometimes a bump in the road does it. If I tap the face of the stereo, the displays will come back up. Sometimes the stereo volume drops to 0, sometime it will continue to play, but with blank displays. Has anyone experienced this? 2007 Legacy specB. No significant mods. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted August 22, 2011 Share Posted August 22, 2011 Sounds like there's a loose connection somewhere. Easiest thing to start with would be pulling the head unit out and making sure the harness is connected securely and that none of the wires are coming loose from the harness. It could be something loose/damaged internally though, in which case you'd have to open up the unit to repair it or replace it. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
whiskywizard Posted August 22, 2011 Author Share Posted August 22, 2011 Yeah - I was thinking loose ground, since both the head unit and the climate control go out together. Link to comment Share on other sites More sharing options...
stclark13 Posted August 22, 2011 Share Posted August 22, 2011 Does the display just go out or do you lose audio too? My display would flicker and go out from time to time but the radio would still work. I removed the radio took off the faceplate which i believe is 6 screws around the bezel. I then rubbed the connectors behind the faceplate and radio with alcohol wipes. Problem never came back. Link to comment Share on other sites More sharing options...
whiskywizard Posted August 24, 2011 Author Share Posted August 24, 2011 Does the display just go out or do you lose audio too? Both - sometimes I lose the display only, and sometimes I lose the display and the audio. Thansk for the suggestion re contacts. Ill give that a try. Link to comment Share on other sites More sharing options...
Fantastipotamus Posted September 11, 2011 Share Posted September 11, 2011 My '07 Spec B does this too, but only if I have the stereo off, for some reason. Also, the climate control still works, but I just can't see the displays. Tapping doesn't get mine to light back up, I have to shut the car off and restart, and it'll resume. Doesn't happen to me often, because my stereo isn't off much. Link to comment Share on other sites More sharing options...
whiskywizard Posted September 14, 2011 Author Share Posted September 14, 2011 Following up with the resolution.... I pulled the stereo/HVAC control unit out of the dash and disconnected all leads. I sprayed the terminals on the head unit and the plugs on the wires (used Fluid Film) and re-installed. So far, the problem seems to be 100% fixed. Link to comment Share on other sites More sharing options...
mrmegadeth Posted September 14, 2011 Share Posted September 14, 2011 I recently had this issue. Both displays would flicker in and out and then eventually everything died. I had to have the HVAC/Head Unit replaced by the dealer. In fact, when the dealer was troubleshooting the issue they said that they could rotate the head unit and strange things would happen (volume going up and down, couldn't turn on/off) so I think there is an internal short on some units. Link to comment Share on other sites More sharing options...
c-lo Posted December 23, 2011 Share Posted December 23, 2011 I've been having this issue every now and then. except mine doesn't come on when i turn the car on. I have to turn the car off/on again and THEN it will come on. have not searched for the resolution yet. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
whiskywizard Posted December 24, 2011 Author Share Posted December 24, 2011 I've been having this issue every now and then. except mine doesn't come on when i turn the car on. I have to turn the car off/on again and THEN it will come on. have not searched for the resolution yet. I posted the resolution in post #7 above. Link to comment Share on other sites More sharing options...
