joeblow Posted August 21, 2011 Share Posted August 21, 2011 So I went out for my first ever autocross today and as I'm sitting in grid, I notice that my car was puffing bluish-white smoke. My first run consisted of large puffs of smoke when I get back on the gas after a turn. I popped the hood and the smoke was coming from around the turbo and out of the exhaust. I made the second run and the smoke wasn't as bad. Third run it was pretty clean. I thought maybe it was just some built up oil from blow by being burnt off because I don't normally beat on my car. Then we break for lunch. I came back for my second heat of 3 runs and ended up dropping out because any time I tapped the gas, it would send a small puff or smoke. A few people suggest a leaking/blown turbo seal? So oil is getting into the exhaust housing of the turbo and causing it to burn off and out the exhaust and some leaking out from around the turbo area. Obviously the car is parked and waiting on me to decide what to do. Does anyone have other suggestions? I'm not much of a diagnoser, but I'll be able to turn the wrenches and swap a turbo or look for issues with the turbo (shaft play, bent fins, etc) It's cool; I'm with the band Link to comment Share on other sites More sharing options...
itsme Posted August 21, 2011 Share Posted August 21, 2011 Take off the DP and see what you find? That is the easiest way to know. Then go from there. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
AZP Installs Posted August 21, 2011 Share Posted August 21, 2011 I would start with a compression test. It is less invasive, and will eliminate the internals from the picture. From there if the compression is good then look at the turbo. Mike Link to comment Share on other sites More sharing options...
