urdrwho Posted August 20, 2011 Share Posted August 20, 2011 After several weeks of owning / driving, yesterday's all day drive produced a bit of smoke of the cat convertor. On my car when I start getting drips off onto the cat convertor it is from a leaking head gasket. My car is a straight head six with half moon seals on the rear and it will leak at the rear corner and roll down onto the cat. On a 95 Legacy could it also be the valve cover gasket. About 170,000 miles on the engine and who knows when it was last changed. Or is there another normal culprit on a 95 legacy wagon? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 20, 2011 I Donated Share Posted August 20, 2011 Your car is a straight head six? What does that mean? If you have a 95 Legacy, is a boxer style 4 cylinder. Your engine is an EJ22. Oil leaks can come from anywhere. There is no "normal culprit". You just have to get under it and look -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
urdrwho Posted August 20, 2011 Author Share Posted August 20, 2011 Oops sorry I wasn't clear. The Legacy is my son's car. "My" car is a Jag XJ6 and that is a straight head six. And on this model Jag there are certain culprits for an oil leak. Nine times out of ten it is the valve cover gasket. I gotta crawl under this new to our family car and check her out. Your car is a straight head six? What does that mean? If you have a 95 Legacy, is a boxer style 4 cylinder. Your engine is an EJ22. Oil leaks can come from anywhere. There is no "normal culprit". You just have to get under it and look Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 20, 2011 I Donated Share Posted August 20, 2011 Valve cover, oil pan, oil separator, heads -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
