JJay03 Posted November 8, 2011 Share Posted November 8, 2011 I will post them up tomorrow when I pick them up. He looked them up in the book so I didnt get the number. Link to comment Share on other sites More sharing options...
ampped88 Posted November 9, 2011 Share Posted November 9, 2011 I ordered 4 new outside stabilizers they call them they should be in on wednesday. I thought about just glueing on new felt but I dont have much time to have the windows out so ordered new ones to be safe. This should not happen again in my lifetime either since I keep it in the garage where the PO did not. where did you order them?? link?? Link to comment Share on other sites More sharing options...
JJay03 Posted November 9, 2011 Share Posted November 9, 2011 where did you order them?? link?? From my local subaru dealer. I found them here also though. https://www.subarugenuineparts.com/oe_parts_cat.html Under front door>door&components>stabilizer Link to comment Share on other sites More sharing options...
Stasis Posted November 9, 2011 Share Posted November 9, 2011 or just give people a link Searched using 1998: https://www.partswebsite.com/subarugenuineparts/?i=2&make=153&model=2033&year=1998&catid=30192&subcatid=63260§ion=129&type=parts Link to comment Share on other sites More sharing options...
eekay Posted November 10, 2011 Share Posted November 10, 2011 JJay, what's the part number for the "stabilizers"? Part number for the outter stabilizer is 61256AE010 (Taken from the picture in the how-to on NASIOC lol) and the inner stabilizer part number is 61256AE001. Order away! My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
JJay03 Posted November 10, 2011 Share Posted November 10, 2011 Part number for the outter stabilizer is 61256AE010 (Taken from the picture in the how-to on NASIOC lol) and the inner stabilizer part number is 61256AE001. Order away! I checked that part number before and thats for a newer model. I didnt get my parts today they suppose to come in tomorrow. Link to comment Share on other sites More sharing options...
eekay Posted November 10, 2011 Share Posted November 10, 2011 Ah. That could be. Browsing around online for the Gen2's it seems the model numbers are 62304FA001 for the inner and 61256FE020 for the outter. Thanks for mentioning. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
JJay03 Posted November 11, 2011 Share Posted November 11, 2011 Ah. That could be. Browsing around online for the Gen2's it seems the model numbers are 62304FA001 for the inner and 61256FE020 for the outter. Thanks for mentioning. Finally picked up mine today and that is the correct part number. Link to comment Share on other sites More sharing options...
JJay03 Posted November 15, 2011 Share Posted November 15, 2011 Got the driver side done I didnt have to take the window all the way out. I just took it out of the rails and dropped it all the way down. The trim piece up top on the outside was also very dirty and I cleaned that out before putting in the new stabilizers. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted November 16, 2011 Author Share Posted November 16, 2011 VaJAYJAY, Post pictures! This would be a perfect how-to or DIY thread to solve a common problem. Link to comment Share on other sites More sharing options...
JJay03 Posted November 16, 2011 Share Posted November 16, 2011 I would of took pictures but the wife had my camera. Once you get the door panel off there is just 2 nuts at the bottom that bolt the window brackets to the rails. Undo those 2 nuts and then you can pull the front out of the rail and drop the window all the way down and get enough room to replace the stabilizers and clean the outside trim. I also tightened up the inside stabilizers a bit and the window doesnt moved a lot like it use to. I also use to have a squeak when I shut the door and that is now gone. Best to have help to hold the window also and be very careful if you have tint not to scratch it. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted November 18, 2011 Author Share Posted November 18, 2011 This is going to be a fun job since I already have the doors from a salvaged car ready in my place then need this work done to them! Link to comment Share on other sites More sharing options...
eekay Posted November 18, 2011 Share Posted November 18, 2011 My stabilizers came today but I'm doing my ECU swap and speed density tune before I put these in. Should be soon though. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
Lsnaple Posted November 19, 2011 Share Posted November 19, 2011 I remember posting in a thread about this on rs25.com. What happens is the dirt and grime and stuff from years of weather etc gets lodged in the pad and eventually enough to scratch it. They had a cheap solution to go to wal-mart or really any store that sells faux fur or whatever, and trim it to the shape of the pad and switch them out. Cheaper than buying oem pads and does the same job. Link to comment Share on other sites More sharing options...
eekay Posted November 20, 2011 Share Posted November 20, 2011 +1 After looking at the stabilizers, it seems really easy to just replace the soft padding. I'll definitely give it a try. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
arlia101 Posted September 18, 2012 Share Posted September 18, 2012 I believe this is the thread referred to by the OP. I also saw it a year + ago, and in deciding to re"fur" the pads now, was absolutely stumped for it. Thanks for the RS25 hint! http://www.rs25.com/forums/f105/t46901-diy-repair-window-pads.html Link to comment Share on other sites More sharing options...
Stasis Posted September 19, 2012 Share Posted September 19, 2012 I used faux fur for mine and gave the pads a hair cut since it was way too long, works really well o-o Link to comment Share on other sites More sharing options...
harrumphicus Posted September 20, 2012 Share Posted September 20, 2012 Subscribed, so I don't forget to do this to mine. I'm not finding the actual window glass anywhere - trying to replace that too, eventually. Link to comment Share on other sites More sharing options...
monkeyposeur Posted September 20, 2012 Share Posted September 20, 2012 I need to do this to both my subies. Link to comment Share on other sites More sharing options...
eekay Posted September 20, 2012 Share Posted September 20, 2012 Works great! Did it myself and I couldn't be happier. Especially after spending only $13 to do the whole "fur swap". Although, I need to find new glass at some point as well... My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
twisty Posted September 20, 2012 Share Posted September 20, 2012 dammit, i went and looked at my window last night after reading this, my tint is scratched to hell on the driver side. i always have the windows down, so ive never paid attention. grrr. time to do this and redo the tint i spose. Link to comment Share on other sites More sharing options...
eekay Posted September 20, 2012 Share Posted September 20, 2012 Yup. Looks like it's time for you to join the club, Sir. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
