WileyKyle Posted August 18, 2011 Share Posted August 18, 2011 After the original turbo died I had a mechanic clean out the engine and put on a rebuilt stock turbo from A1 Turbo in LA. The car has run fine for 200 miles now, except that it is making this screaming noise when the turbo spools. Please give the video a listen. Link to comment Share on other sites More sharing options...
frank_ster Posted August 18, 2011 Share Posted August 18, 2011 badddddd it might be a hose or some thing loose making the sound .. ( do you have a scarcastic mechanic ? did he by any chance put a duck call in your bov ? [ame=http://www.youtube.com/watch?v=N4NBBrujJO0&feature=related]Turkey Call BOV - YouTube[/ame] Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted August 18, 2011 Share Posted August 18, 2011 i don't think its the turbo it self because the sound goes away as soon as you let off the throttle and the bov opens. check intercooler and the hose going to the throttle body. see if you can get some one to rev it as you listen under the hood. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2011 Share Posted August 19, 2011 You can take a pint paint can and stick it in the air inlet hose off the air cleaner box, then pull the small hose form the BOV and give it a short blast of air and listen for leaks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
