vicdeng Posted August 13, 2011 Share Posted August 13, 2011 hi, my ac is not working, i can hear the evaporator is leaking under the dash when i turn my ac on. Is it easy to fix it? or worth it? i have the mechanic at the dealer to check out the leak with the proper tool. So is it easy to replace the evaporator? i think i have some sources to get a used one for cheap. If someone has done this before, plz chime in. Thanks Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 13, 2011 I Donated Share Posted August 13, 2011 You don't have a 1995 Legacy GT. They didn't make them until 1996. Is it leaking freon? how can you hear it leaking freon? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
vicdeng Posted August 14, 2011 Author Share Posted August 14, 2011 it's a 96 lgt with 95 2.2L motor in it. when i turn the ac on, i can hear the leaking sound, and when i turn it off, it disappear. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 14, 2011 I Donated Share Posted August 14, 2011 what kind of leaking sound? A hiss, a drip, a dribble, a growl, a moan, a scream, a whistle, a screech...... Be more descriptive -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
vicdeng Posted August 14, 2011 Author Share Posted August 14, 2011 more like a hiss. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 14, 2011 I Donated Share Posted August 14, 2011 How long has it been doing it? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
vicdeng Posted August 14, 2011 Author Share Posted August 14, 2011 it wasn't doing it before, because my mechanic vacuum everything out, and when he want to put freon back, the computer said it can't be put in more than 0.23g, which indicates that has a leak. Yesterday, he continued and tried to fix it the leak, he vacuum everything first, and then try to put it, this time, the error msg wasn't there, so he kept charging, because he has to put some freon in in order to find the leak. Once the system stops around 0.23-0.25g, we disconnected everything and turn on the ac, and we can start hearing it....before it was not doing because there wasn't any freon in it. Now, even with some freon in it, it is still not blowing cool air...still blowing warm air... any input? Link to comment Share on other sites More sharing options...
vicdeng Posted August 16, 2011 Author Share Posted August 16, 2011 anyone? Link to comment Share on other sites More sharing options...
Chasing my tail Posted August 17, 2011 Share Posted August 17, 2011 If you have a 96, your mechanic shouldnt be adding R12 to your R134, and if the leak is as bad as you say you should be able to see an oily residue where it is leaking, at the least, he should have a leak detector, if it hiss's loud enough for you to hear it a detector should have no prob's finding it. Link to comment Share on other sites More sharing options...
jamesm113 Posted August 17, 2011 Share Posted August 17, 2011 Get a black light and use UV dyed r134 to track down the leak Link to comment Share on other sites More sharing options...
