jbrown Posted August 21, 2011 Share Posted August 21, 2011 So just an update, I did install my Perrin sway bar and I drove around for two miles and what a difference, however turning in to my driveway (on my way back) I heard something fall off, both endlinks are now broken:) xero287 I should have read your post sooner... But let me tell you for those who are limited on tools spraying the bolts before install definitely made everything easier, I only had 1 bolt round off! Pb blaster ftw Link to comment Share on other sites More sharing options...
tito_b0y Posted August 21, 2011 Share Posted August 21, 2011 So just an update, I did install my Perrin sway bar and I drove around for two miles and what a difference, however turning in to my driveway (on my way back) I heard something fall off, both endlinks are now broken xero287 I should have read your post sooner... But let me tell you for those who are limited on tools spraying the bolts before install definitely made everything easier, I only had 1 bolt round off! Pb blaster ftw Wait, so you broke both the Kartboy endlinks? What size Perrin? I have the 22mm one. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
leftcoast74 Posted August 21, 2011 Share Posted August 21, 2011 ^What he said! Broken? WHAT? I'm running 25mm f/r w KB solids & on coils. Can u post a pic of the broken el? Link to comment Share on other sites More sharing options...
xero287 Posted August 21, 2011 Share Posted August 21, 2011 He made the mistake of being normal bolts/nuts/washers, when the ones that kartboy sends you are SIGNIFICANTLY bigger; ie. If the washer is not big enough then it'll pierce right though the rubber bushings and start to push the internal metal bushing out. Happened on all 4 of my endlinks, but hey I practically have brand new ones now since I replaced all 4 with new bushings from kartboy =) Link to comment Share on other sites More sharing options...
tito_b0y Posted August 21, 2011 Share Posted August 21, 2011 ^ I understand that. But I'm wondering about the state of which they are broken. In my head, I'm picturing broken where it connects, or in half, which I'd like to see pictures of since I've never seen a broken Kartboy endlink as those bones are thick. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
xero287 Posted August 22, 2011 Share Posted August 22, 2011 I dont think the endlink is actually broken, instead I think the bushing is. If the bushing rips far enough, (in my case it did) then the head of the bolt will just chill inside of the endlink with no support, if both bushing rip (top and bottom) then I supposed the endlink would just fall off. Link to comment Share on other sites More sharing options...
jbrown Posted August 22, 2011 Share Posted August 22, 2011 Hey guys, xero287 is correct, just the bushings are broken, but I did use the right bolts from lowes, they were the exact ones I got from fredbeans. The only thing is I rushed getting this done at the end, Fredbeans never sent my bolts(the first time) and said they would arrive that day but never did and since I didn't buy the washers it was my screw up. Sorry for not explaining that those steel links are bullet proof! Link to comment Share on other sites More sharing options...
