shtbxr22 Posted August 5, 2011 Author Share Posted August 5, 2011 http://www.ecu-mods.com Link to comment Share on other sites More sharing options...
Legend Posted August 5, 2011 Share Posted August 5, 2011 www.ecu-mods.com Prices have gone up. Think I paid $25-$30. Are these the tinywrx patches or has someone else gone into business here? BTW, OP, you may want to review my OS LC and FFS thread from 2.5 years ago... My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
sjwelna Posted August 5, 2011 Share Posted August 5, 2011 Follow their instructions. Set the LC offset to 3500 RPM first (remember the offset is subtracted from your red line). I recommend using it more as a 2-step (light throttle) to just hold the revs before you quickly and smoothly give the clutch just a little bit of slip. Also, don't sit there bouncing off the limiter. Your EGT's skyrocket and the car wants to heatsoak during LC, so at most hold it for a few seconds as the lights drop. ^------one of the most important posts in this thread so far. Having a second stage rev limiter for launching IS really nice. Just don't use it so you can launch WOT and side-step the clutch....unless you really like pulling trannys that is. -Steve Link to comment Share on other sites More sharing options...
GTTuner Posted August 5, 2011 Share Posted August 5, 2011 I had an issue with logs dropping out using my VAG-COM. I think I was trying to look at too much data. I eliminated some of the logging parameters to quicken up the sampling rate and it took care of the problem. What are you using for logging? RomRaider? I had the problem using another program, or an older program (ECU explorer). Rom Raider works fine. Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 5, 2011 Author Share Posted August 5, 2011 I use romraider, and I have tried cutting back on items logged. Makes no change unfortunately. Link to comment Share on other sites More sharing options...
liljonson Posted August 6, 2011 Share Posted August 6, 2011 Follow their instructions. Set the LC offset to 3500 RPM first (remember the offset is subtracted from your red line). I recommend using it more as a 2-step (light throttle) to just hold the revs before you quickly and smoothly give the clutch just a little bit of slip. Also, don't sit there bouncing off the limiter. Your EGT's skyrocket and the car wants to heatsoak during LC, so at most hold it for a few seconds as the lights drop. do it this way and it works good. i've used it 4 times just to make people jealous. My tranny and clutch are still fine...for now Link to comment Share on other sites More sharing options...
NSFW Posted August 7, 2011 Share Posted August 7, 2011 I need to figure out my logging issues for that. 1 out of 5 of my WOT logs are usable. Most have huge chunks of info that just disappear. I've heard that logging with a 1.3 Tactrix or vag-com cable remedies this. Any experience? I have a 1.3 and had no issues for years, but then for a week or three it would cut out around 4000-5000 RPM. I tried removing power to the DCCD controller I installed at the same time, but that didn't change anything. Tried putting chokes on the Tactrix cable and on the new DCCD wiring (it has a wire that goes to the ECU's TPS pin), those didn't help. Reduced my timing a bit, and the problem went away. Funny coincidence. Around the same time, two of the reverse-engineering guys at RomRaider mentioned that they found some code in the ECU that causes the data logging communications to glitch when there's knock. So if I was you I'd pull timing at the load and RPM where your logs cut out, and see if that helps. The logs might be cutting out right around where you're knocking. If they are, that's bad and it should be fixed. I like launching the old-fashioned way, but I could see FFS being pretty useful. Someone over at NASIOC said he had really good results setting FFS up so that it cut fuel at the normal redline, and didn't resume fuel until a much power RPM (5000, maybe, I don't really remember) or, more importantly, when the clutch was released. The idea was to just let the motor spin down with the throttle plate wide open so you maintain boost but don't bounce off the rev limiter. I haven't tried it yet, but it's tantalizing. The patches at ecu-modes.com don't seem to allow setting the fuel-cut and fuel-resume independently, though. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 7, 2011 Share Posted August 7, 2011 ^if you can find a link to that NASIOC post link it NSFW? pay to play......another useless post. expected. Funny I was thinking the same thing. As long as you dont mind me quoting you EDIT: I *DID* try to find it. Link to comment Share on other sites More sharing options...
NSFW Posted August 8, 2011 Share Posted August 8, 2011 I spent a few minute searching just now, but couldn't find it. Link to comment Share on other sites More sharing options...
lil_z_33 Posted August 8, 2011 Share Posted August 8, 2011 so I think I'm gonna get the $35 launch control from ecu mods, do I need my OS tune on my laptop to be able to apply this? I do not have a copy of the tune, nor have I ever loaded a tune on my car...my tuner and the shop that did the install has a copy of the tune...will they have to patch it in for me? Link to comment Share on other sites More sharing options...
SSpeed Posted August 8, 2011 Share Posted August 8, 2011 You should be able to dump out your tune with ECUFlash as long as it was an opensource tune. Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 9, 2011 Author Share Posted August 9, 2011 unless they locked it... Link to comment Share on other sites More sharing options...
shtbxr22 Posted September 8, 2011 Author Share Posted September 8, 2011 So niko has completed FFS/LC for Spec B http://www.ecu-mods.com/online/index.php?act=viewProd&productId=126 stay tuned! Link to comment Share on other sites More sharing options...
