LGT Steve Posted August 2, 2011 Share Posted August 2, 2011 I just bought this 2006 Legacy GT lmt.. in Nov of last year.. I checked the oil in March and it was 3 quarts low and then I filled it up.. took it to the track and blew up teh Turbo.. os with a new turbo installed and new oil.... just checked it again and it is 3 quarts low again? Is this normal for the Legacy 2.5? or what? thanks for any help Steve Link to comment Share on other sites More sharing options...
Max Capacity Posted August 2, 2011 Share Posted August 2, 2011 Yes. You need to learn how to check the oil and top it off as needed. These things like oil. My 05 started using oil at about 75,000 miles. To check the oil, I drive to work, open the hood, pull the dip stick about 2" close the hood go to work. 8 Hours later, open the hood wipe the stick check the oil. If it reads low or like my 09 Spec B the oil level forms a V, flip the stick around and read the back of it. I sometime loosen the oil fill cap too. ALWAYS top it off as needed. Oh welcome to the forum. Lots of info here, hope you like to read. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Balrock Posted August 3, 2011 Share Posted August 3, 2011 According to Subaru, 1qt every 1,000 miles is "normal". That being said, the only time I know of a Subie eating that much oil is from a cracked ringland. You might want to consider a compression test. With all my mods and my heavy foot I might eat a half quart every 3,000 miles. Can't hurt. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 3, 2011 Share Posted August 3, 2011 All signs point to a cracked ringland. As balrock01 said, get a compression test... -mike Link to comment Share on other sites More sharing options...
