.blackgt. Posted July 30, 2011 Share Posted July 30, 2011 I am looking at purchasing top feed pink sti injectors for my legacy. I was going to send them out to witchhunter and get them modded. I want to keep my light blue oem injectors so that I can revert to stock if need be. Does anyone know if they will fit? Link to comment Share on other sites More sharing options...
IDRVSLO Posted July 30, 2011 Share Posted July 30, 2011 Yes, top feed for top feed is a direct swap. [ Link to comment Share on other sites More sharing options...
babybluelgt Posted July 31, 2011 Share Posted July 31, 2011 I wouldn't recommend getting your injectors modded. Although witchhunter does good work, there is no way to get all 4 injectors to flow exactly the same. Your best option is to spend more money and buy a set of new better flowing injectors, and not risk blowing your motor. Link to comment Share on other sites More sharing options...
IDRVSLO Posted July 31, 2011 Share Posted July 31, 2011 From what I understand they do not mod your set of injectors. They only used yours as an exchange. They match even flowing injectors and send them to you. [ Link to comment Share on other sites More sharing options...
babybluelgt Posted August 9, 2011 Share Posted August 9, 2011 I believe they do mod your injectors. If you insist on going this route I recommend sending them at least 8. They will mod all of them, but only send back the closest 4. And you only pay for the 4 they send back Link to comment Share on other sites More sharing options...
