TbirdMan Posted July 30, 2011 Share Posted July 30, 2011 well, my AWD is whining and i am pretty sure I need new tires (FWD fuse is in for now) I have 215/55/16 on it now and would like to stay with that. I know OEM 205/55/16 are a bit smaller in daimeter (about .4-.5in) this shouldn't throwing the speedo off too much should it? the tires I am looking at are Kuhmo Ecsta LX Platinum, anyone try these yet? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 30, 2011 I Donated Share Posted July 30, 2011 If you want Kuhmos, I suggest the Exsta ASX tires. I have had them and they are great You will be just fine running 215s. Speedometer readings will be marginally different at best. You would never notice. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
WESTcoast Posted July 30, 2011 Share Posted July 30, 2011 yup im running 215/55/16 on my stock, i only rub at full lock and plus it doesnt help that im lowered. Plus 1 to the exsta asx tires!! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 31, 2011 I Donated Share Posted July 31, 2011 Forgot to mention...if your AWD is whining...its not because of your tires. Sounds like a center diff problem -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
subikid90 Posted July 31, 2011 Share Posted July 31, 2011 If you want Kuhmos, I suggest the Exsta ASX tires. I have had them and they are great You will be just fine running 215s. Speedometer readings will be marginally different at best. You would never notice. +1 to the asx's -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Frogg Posted July 31, 2011 Share Posted July 31, 2011 ive never liked kumho. imo much better tires are out there Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 31, 2011 I Donated Share Posted July 31, 2011 ive never liked kumho. imo much better tires are out there There are much better tires out there, however for someone on a budget Kuhmos seem to be the best "budget tire" You can buy a set of Kuhmo ASXs for around 400 bucks new installed. If you get into "better" tires, they go up into the $1500 range installed. My tires were $1200 (not installed) -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Frogg Posted July 31, 2011 Share Posted July 31, 2011 i understand but even in the same price range, i feel there are better ones... Link to comment Share on other sites More sharing options...
TbirdMan Posted August 1, 2011 Author Share Posted August 1, 2011 Well, It started whining after i fixed the AWD, long story but the short version was there was a dime shoved in the Transfer Control valve port. it was fine for a few days, but suddenly started whining. I put the FWD fuse in and it stopped completely. I really hope it is just tires (one in particular is badly worn on the inside due to bad alignment) I have already had to tear into the transfer section twice and I don't want to get in there again. My assumption is that under normal driving the AWD should not be engaged? since the FWD fuse stops the whine it is obviously coming from the AWD engaging. the only other possibility would be the rear tail shaft bearing, and I am hoping it isn't that. the whine sounds to me more like gears binding up. Link to comment Share on other sites More sharing options...
TbirdMan Posted August 1, 2011 Author Share Posted August 1, 2011 Also, the reason i want the Kumho Ecsta LX Platinum is for winter weather traction, and it has double the tread-life warranty of the ASX Link to comment Share on other sites More sharing options...
