SSpeed Posted July 28, 2011 Share Posted July 28, 2011 If so, any change I could take a look underhood for a new project I'm up to? I'll buy Sonic... Link to comment Share on other sites More sharing options...
Richard T Posted July 28, 2011 Share Posted July 28, 2011 I've got a friend I could contact, but you'd likely have better luck on AWDPirates.net. Just throwing it out there. I'll see if my buddy is interested in the short term. Link to comment Share on other sites More sharing options...
rweezy Posted July 29, 2011 Share Posted July 29, 2011 rkl303 has one haven't seen him online in awhile. Bought some parts from him, good guy to talk with. Maybe try shootin him a pm. If so, any change I could take a look underhood for a new project I'm up to? I'll buy Sonic... Link to comment Share on other sites More sharing options...
rweezy Posted July 29, 2011 Share Posted July 29, 2011 actually now that i think about it i think he has an sti, probably not what your lookin for. Link to comment Share on other sites More sharing options...
fahr_side Posted July 29, 2011 Share Posted July 29, 2011 I don't live in CO (fahr, fahr away) but I'm curious to know what you're up to, own an '08 WRX and have tape measures / calipers... Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
LGT For ME Posted July 29, 2011 Share Posted July 29, 2011 SSpeed, Eric w/ torqued performance has a 08-09 wrx that I'm sure you could check out. Its currently out of commission as his big turbo build spun a bearing or something like that so its in rebuild mode. Link to comment Share on other sites More sharing options...
SSpeed Posted July 29, 2011 Author Share Posted July 29, 2011 ^^ Nothing all that exciting really.... I'm going with a ProcessWest intercooler, so I'm ditching my engine cover... For aesthetics, and possibly a conspiracy theory of my own that it does a little for underhood aerodynamics, I'm wanting to go with the '08 WRX belt cover... I've acquired the cover #3, but need to know what brackets I also need... the only halfway good pictures I've gotten are from subarupartsstore.net http://i85.photobucket.com/albums/k62/dil222/subaru-impreza-wrx-engine-bay-634x424.jpg #4 surely is needed, wondering where it bolts up to though... and then how the left side of #3 is secured, is it a bolt on an existing bracket? Really just want to sit the two side by side and compare, but I'd take you up on pics and measurements fahr_side! http://i85.photobucket.com/albums/k62/dil222/bracket.jpg Thanks LGT for Me, maybe I'll give him a call on it and see if I can just peek... Link to comment Share on other sites More sharing options...
fahr_side Posted July 29, 2011 Share Posted July 29, 2011 OK, no problem. The passenger side of the cover is fixed with an M6 bolt into a bracket which is bolted to the power steering pump. The driver side has a plastic molded spike with pushes into a rubber grommet on another bracket, which is in your diagram is #4. This in turn is fixed by the alternator pivot bolt. The photos should make it pretty clear what you need. I was going to give you link to the drawings on opposedforces.com but they seem to be down... Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SSpeed Posted July 29, 2011 Author Share Posted July 29, 2011 ^^ Thank you much! Now I just need to find the part numbers on the two brackets... The driver side bracket is #4 and I can order it without part #, need to find the passenger side one though... Your pictures help greatly, thanks! Link to comment Share on other sites More sharing options...
fahr_side Posted July 30, 2011 Share Posted July 30, 2011 23791AA002 is the bracket on the alternator and 34446AG020 is the bracket off the PS pump. Opposedforces is back up. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SSpeed Posted July 30, 2011 Author Share Posted July 30, 2011 You are awesome, thank you! Link to comment Share on other sites More sharing options...
fahr_side Posted July 31, 2011 Share Posted July 31, 2011 See, I'm not that bad, when you get to know me. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SSpeed Posted September 14, 2011 Author Share Posted September 14, 2011 Just a follow-up to this... in anticipation of my nifty ProcessWest intercooler getting here, I installed the WRX belt cover today (my first aesthetic mod) since I'm not driving the car anyway. Fits beautifully, just need the alternator side bracket, WRX cover, and a really long M5 bolt to make it work. Looks much cleaner than the big engine cover... Link to comment Share on other sites More sharing options...
SCASEYS Posted March 11, 2016 Share Posted March 11, 2016 already have #4 do I just need #3 to make it work? I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
fahr_side Posted March 15, 2016 Share Posted March 15, 2016 Just check on the existing bracket if there's a hole and captive nut right above the PS pump pulley. If it's there the other two parts should PnP. Sent from a device using some software. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
