jblackwell1 Posted July 28, 2011 Share Posted July 28, 2011 Im currently looking for turbos for my build and am wondering what all it would take to run a blouch or similar STi fitment turbo on my LGT. I know intake mani would have to change but im wondering what else i would have to change to get these turbos to run on the legacys. UP? FMIC piping? Thanks JB Link to comment Share on other sites More sharing options...
W1CKED Posted July 28, 2011 Share Posted July 28, 2011 http://luckybob.smugmug.com/Cars/LegacyGT-Related/i-6hnDjB6/0/O/noob-small.png 21 Different Threads Found When Searched "STI Turbo" Link to comment Share on other sites More sharing options...
jblackwell1 Posted July 28, 2011 Author Share Posted July 28, 2011 Sorry. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 28, 2011 Share Posted July 28, 2011 Im currently looking for turbos for my build and am wondering what all it would take to run a blouch or similar STi fitment turbo on my LGT. I know intake mani would have to change but im wondering what else i would have to change to get these turbos to run on the legacys. UP? FMIC piping? Thanks JB You could do all that or get a rotated UP and FMIC with those two components you can run any turbo you like as long as you have the UP and DP flanges to match Link to comment Share on other sites More sharing options...
W1CKED Posted July 28, 2011 Share Posted July 28, 2011 You don't have to apologize. Link to comment Share on other sites More sharing options...
WhiskeyTango Posted July 28, 2011 Share Posted July 28, 2011 It bolts right in, no mods or tune needed. Link to comment Share on other sites More sharing options...
jblackwell1 Posted July 28, 2011 Author Share Posted July 28, 2011 You could do all that or get a rotated UP and FMIC with those two components you can run any turbo you like as long as you have the UP and DP flanges to match Have FMIC but already bought new DP and UP which would suck to have to hack up. Ill read through the threads and see whats cheapest to run what i want Link to comment Share on other sites More sharing options...
jblackwell1 Posted July 28, 2011 Author Share Posted July 28, 2011 It bolts right in, no mods or tune needed. Thats what i figured Link to comment Share on other sites More sharing options...
mattg Posted July 28, 2011 Share Posted July 28, 2011 UP & DP will be the same between LGT and STi fitment. Only thing that matters is how you connect your compressor outlet and interchiller. Link to comment Share on other sites More sharing options...
MrHellrais3R Posted July 29, 2011 Share Posted July 29, 2011 Your fmic should allow you to use an sti style turbo. The only difference is the connecting for the intercooler. Lgt style is with the 2 hole flange and sti style turbos are connected with just a coupler. The FMS fmic should have both pipes included with the kit iirc. Everything else is the same. If you went with a rotated set up, the benefits are that you can run a much larger turbo and also set it up as a blow through setup. This allows you to run off of speed density rather than Maf scaling for a/f ratio. Pretty cool when your running a big maf with larger injectors and don't want to have to tune for the maf. Speed density just runs off of engine speed; same power at any altitude. Link to comment Share on other sites More sharing options...
jblackwell1 Posted July 29, 2011 Author Share Posted July 29, 2011 Awesome thanks for the info. I really need to figure out my turbo and this helps a lot. Im hoping to find one before i go to bed tonite Link to comment Share on other sites More sharing options...
