dshotterSD Posted July 26, 2011 Share Posted July 26, 2011 I was putting on a spare tire and saw something that does not look good. I don't know much about cars so I would like to ask the experts This is on the front passenger side, it looks like oil is leaking. Is this bad?? I know its not good...anyone feel free to chime in thank you http://img.photobucket.com/albums/v436/Dshotter/problem.jpg Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 26, 2011 Share Posted July 26, 2011 Boot is torn. If it's been that way for a while then you'll have no choice, really, but to replace the axle. And holy crap that's a blurry picture! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Max Capacity Posted July 26, 2011 Share Posted July 26, 2011 FWIW, I got a replacement axle from the local auto parts store for $80.00 and replaced it my self. Unless this is covered by the dealer, don't go there. They will charge you about $400. or more to replace it. Go to a local repair shop, this is a easy job for them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted July 26, 2011 Share Posted July 26, 2011 We charge 260 installed for front axles. The legacies go through them every 60k miles or so on turbo cars. Take it to infamous performance in so cal. Great guys and reputable place. I know them personally and they are like the AZP of the west coast. Mike Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 26, 2011 Share Posted July 26, 2011 We charge 260 installed for front axles. The legacies go through them every 60k miles or so on turbo cars. Take it to infamous performance in so cal. Great guys and reputable place. I know them personally and they are like the AZP of the west coast. Mike Orly? Because of the downpipe? Looks like I've solved that. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
AZP Installs Posted July 26, 2011 Share Posted July 26, 2011 Yup the heat from the downpipe causes the boots to dry and crack. Even on totally stock cars. Mike Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 26, 2011 Share Posted July 26, 2011 It's odd that I never had that happen on any of my other cars. Regardless, I don't think that'll happen to me. Judging by temp measurements, my CV boot is no warmer now than it was with the stock downpipe. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
DocHolladay23 Posted July 26, 2011 Share Posted July 26, 2011 I was going to ask you BAC, how/where did you install that heatshield? [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 26, 2011 Share Posted July 26, 2011 I'll snap a pic today if I can. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
DocHolladay23 Posted July 26, 2011 Share Posted July 26, 2011 Sounds good. And to end the thread jack, mine did the same thing recently OP, nothing to worry about just replace the axle and enjoy cleaning all that grease off (I know I had fun ) [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
compsurge Posted July 26, 2011 Share Posted July 26, 2011 I can't tell if the boot is torn, it might just be the smaller clamp is loose. On mine, I have to replace the small front clamps on both front L/R as it causing the boots to lose a small amount of grease. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2011 Share Posted July 27, 2011 In case you have trouble getting the axle to seat into the tranny. http://legacygt.com/forums/showthread.php/installing-axles-166892.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dshotterSD Posted July 27, 2011 Author Share Posted July 27, 2011 Thanks for the replies. I just got 4 new tires because the one tire that was on this part of the car was severely chopped on the inside. Could this make a tire get "chopped"? Also, is it best to replace both front axles - or can I just do one? Here's a better picture....not sure if it helps since you can pretty much tell whats going on in the first picture. I will have my friend look at it to see if the smaller clamp is lose, or if I need a new axle http://img.photobucket.com/albums/v436/Dshotter/driveshaft.jpg Link to comment Share on other sites More sharing options...
DocHolladay23 Posted July 27, 2011 Share Posted July 27, 2011 Still hard to see, the place to look is that black rubber boot. It's pretty common for the passenger front one to crack/rip due to it being so close to the downpipe and subjected to the heat. All that crud is grease, not oil, and IMO this wouldn't really have anything to do with the tire failure. You can do just that side, no need to replace the driver's side unless it is also torn or the CV joint is making noise. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
AZP Installs Posted July 27, 2011 Share Posted July 27, 2011 Still hard to see, the place to look is that black rubber boot. It's pretty common for the passenger front one to crack/rip due to it being so close to the downpipe and subjected to the heat. All that crud is grease, not oil, and IMO this wouldn't really have anything to do with the tire failure. You can do just that side, no need to replace the driver's side unless it is also torn or the CV joint is making noise. Yup that's grease. Anytime the boot is breached it's best to replace the whole axle/cv combo because the grease usually becomes contaminated. You only need to do the one that is leaking. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.138.AZP1(2971)| T-1 Certified Amsoil Direct Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted July 29, 2011 Share Posted July 29, 2011 from what i can see your boot is actually not split open. its leaking out from the clamp loosing up. this is not uncommon and is actually happening on my vehicle. its totally up to you on how to fix it. i recommend taking the axle out taking the joint apart wiping as much of the grease out as you can and putting in new grease and installing a new boot. since im a mechanic and im lazy when it comes to my own car. im going to cut off the old clamp force out as much old grease as i can then insert a grease gun with a needle like tip (not through boot but between boot and axle) and if i get lucky be able to squirt new grease in. then ill just put a new clamp on. saving me about 1-1.5 hours in work. Link to comment Share on other sites More sharing options...
