dickey655 Posted July 25, 2011 Share Posted July 25, 2011 Have a 91 legacy fwd. It is throwing a code which will sometimes go off then come back on. When i start the car it will do a very sporadic idle that starts to climb over 1grand then goes down and back up then down again then eventually levels off. have not been able to check the code yet but does anyone know what this might be caused by. It drives fine after start up it just does this first when starting. any advice is appreciated thank you Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 25, 2011 Share Posted July 25, 2011 Mine does that too. It's a symptom of having a 20 year old car. At first mine will jump up to 1k and then it'll fall til about 500 for a second then level off at 750. Stupid OBDI is hard to check cause the lights dont always stay. Especially that stupid knock sensor light. Link to comment Share on other sites More sharing options...
enzotheracer Posted August 2, 2011 Share Posted August 2, 2011 having that exact same problem. i was going to replace the iac (idle air control) but no one makes one anymore. not even suby themselves. Link to comment Share on other sites More sharing options...
Justin Forsythe Posted August 3, 2011 Share Posted August 3, 2011 I have read other discussions about similiar symptoms and the topic was the fuel pump, they said try priming the fuel pump 2-3 times before cranking over. the reason being there is gas still in the line when you shut your car off, and the fuel pump disengages. Well when you start your car again the gas that was left in the line burns first then theres a pocket of air at which point your car would idle down, until the fresh gas from the pump reaches the injectors. I would definetly still check the codes though. hope this was helpful Link to comment Share on other sites More sharing options...
enzotheracer Posted August 3, 2011 Share Posted August 3, 2011 i have a high idle and sometimes it goes down to 700 where it should be. so i set the idle to the load 800 so that i know i'm not running lean. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted August 4, 2011 Share Posted August 4, 2011 You could always find an IAC in a junk yard. They're usually no more than $20. I've gotten one for $5 before. Link to comment Share on other sites More sharing options...
