David E Posted July 22, 2011 Share Posted July 22, 2011 1999 Legacy Outback wagon. Drivers side window is operating intermitantly and I think it is the switch. Sometimes when I start the car there is a short buzzing noise coming from the left side under the dash. Also, when the window is down it sometimes makes little jerks up, like it is trying to go up on it's own. Before I go tearing anything apart thought I'd see if anyone else has had the same experience. Thanks. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 22, 2011 I Donated Share Posted July 22, 2011 Sounds like the window regulator (window motor) is going bad. Easy fix -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
David E Posted August 6, 2011 Author Share Posted August 6, 2011 Thought I'd update on this. The window problem was caused by my alternator starting to go bad...When my alternator died last week I grabbed my son, pulled the alternator and took it to AutoZone. They tested it and it was bad. Son and I installed a rebuilt one and a couple of days later noticed my window problem was gone, with no reoccurence. I've had a couple of pretty good mechanics tell me "modern" cars are exceptionally sensitive to voltage. Probably one reason the grounding mod seems to help so much. Guess that will be next on my list of things to do. Link to comment Share on other sites More sharing options...
