rob-2 Posted July 21, 2011 Share Posted July 21, 2011 Do we have a DIY for this? If not I will make one, or at least take some pictures and someone can tell me the proper steps Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2011 Share Posted July 21, 2011 I didn't change my coolant until I replaced the timing belt at 95,000 miles. I just refilled it with 50/50 mix of Prestone and water. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted July 21, 2011 Author Share Posted July 21, 2011 I didn't change my coolant until I replaced the timing belt at 95,000 miles. I just refilled it with 50/50 mix of Prestone and water. I thought it could go that long too. I will check level when cold Coolant is a PITA. No one wants to take it. Link to comment Share on other sites More sharing options...
bmx045 Posted July 22, 2011 Share Posted July 22, 2011 Unclamp the lower radiator hose and take off the two radiator caps, let it drain. replace the rad cap and lower hose, and fill via the turbo resevior, burb system as you fill by squeezing the upper and lower rad hose, stop when it starts to overflow at res, check the level AT the turbo res tank the next day Link to comment Share on other sites More sharing options...
