Moderators BarManBean Posted March 24, 2013 Moderators Share Posted March 24, 2013 No need to replace that filter unless it's physically damaged. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 25, 2013 Share Posted March 25, 2013 No need to replace that filter unless it's physically damaged. Isn't it a filter afterall? What is the purpose of the filter? Isn't it to filter out contaminants from the fluid? I'd rather replace a filter than tranny from damage done by dirt/shavings. Perhaps Subaru would like you to buy a transmission from them rather than replacing a filter. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 25, 2013 Moderators Share Posted March 25, 2013 Isn't it a filter afterall? What is the purpose of the filter? Isn't it to filter out contaminants from the fluid? I'd rather replace a filter than tranny from damage done by dirt/shavings. Perhaps Subaru would like you to buy a transmission from them rather than replacing a filter. Don't forget to wear your tin foil hat when you sleep, otherwise the government will steal your dreams... There's no harm in changing it if you feel like spending the money. Make sure you don't leave the o-ring on there though, as it apparently has a tendency to stick and keeping two o-rings there will result in a leak. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 26, 2013 Share Posted March 26, 2013 Don't forget to wear your tin foil hat when you sleep, otherwise the government will steal your dreams... There's no harm in changing it if you feel like spending the money. Make sure you don't leave the o-ring on there though, as it apparently has a tendency to stick and keeping two o-rings there will result in a leak. Our car has over 100K miles on it, it wouldn't hurt to change it at that many miles. Link to comment Share on other sites More sharing options...
El Capitan Posted March 31, 2013 Share Posted March 31, 2013 Hi. I have 2007 subaru outback sedan 3.0 H6,with 5AT.I want to change oil in both diffs.In owners manual there is written that it needs oil 75w90 GL-5. The only problem is that I live in Europe,Georgia and here is only Motul gear 300 and Motul gear 300 LS.Motul gear 300 is GL-4/5,and gear300LS is GL-5,bat it has LS additives.please I need advise,which fluid is better and can I use this GL-5 LSD in my front or rear diff? Thank you. Link to comment Share on other sites More sharing options...
theflystyle Posted April 14, 2013 Share Posted April 14, 2013 Hi. I have 2007 subaru outback sedan 3.0 H6,with 5AT.I want to change oil in both diffs.In owners manual there is written that it needs oil 75w90 GL-5. The only problem is that I live in Europe,Georgia and here is only Motul gear 300 and Motul gear 300 LS.Motul gear 300 is GL-4/5,and gear300LS is GL-5,bat it has LS additives.please I need advise,which fluid is better and can I use this GL-5 LSD in my front or rear diff? Thank you. From my understanding, as long as its GL-5 rated it should be OK. Link to comment Share on other sites More sharing options...
theflystyle Posted April 14, 2013 Share Posted April 14, 2013 Does that seem like a bit much to anyone lol?? Before / After http://i306.photobucket.com/albums/nn257/theflystyle/reardiff_zpse4d92f10.jpg Link to comment Share on other sites More sharing options...
fstaslp Posted April 14, 2013 Share Posted April 14, 2013 is that cooked on gunk?!?!?! Link to comment Share on other sites More sharing options...
theflystyle Posted April 14, 2013 Share Posted April 14, 2013 shavings from the rear diff... after seeing that i pumped in plenty of fluid to clear out what I could. i plan on doing the changes a little more frequently Link to comment Share on other sites More sharing options...
