turbotaz Posted June 6, 2005 Share Posted June 6, 2005 Has anyone used this rack? I've always had a roof rack, but with the huge sunroof that I really enjoy using, I don't want to have roof bars on full time. I also don't want to bother with a hitch. http://www.orsracksdirect.com/saris-bones-trunk-bike-rack-2-805.html Link to comment Share on other sites More sharing options...
rosta Posted June 6, 2005 Share Posted June 6, 2005 The Bones Series are fine racks. I would be concerned with the upper attachment points. It is far more ideal to have a straight line between attachment point and the rack. The upper straps will have to go around the spoiler and may put too much pressure on it. Also, any time you use a trunk style rack you are endangering your cars finish. I would opt for a hitch rack. Sure it's 5 times more expensive but it's much more stable, safer and has better security options. I used to use a CycleOn on my '99 Legacy wagon but am planning on going back to a roof rack on the LGT. Pedal on, Ross Link to comment Share on other sites More sharing options...
Edvig Posted June 6, 2005 Share Posted June 6, 2005 I have a Saris Bones rack for my Legacy...but I haven't actually used it yet. I've fit the rack on the car, but I've been using the roof rack on my WRX. One side of the Bones rack will sit on the rear window and the other on the top of the rear bumper (the black part) so there shouldn't be any paint damage. However, the C-hooks do look like they would pull the spoiler off. The fit guide on the Saris site suggests getting a set of the Hatch Huggers and replace the C-hooks. I have a set of the Hatch Huggers and they look like they will work fine. I'll post back up if I ever get around to using my Bones rack. Link to comment Share on other sites More sharing options...
turbotaz Posted June 17, 2005 Author Share Posted June 17, 2005 Well, I tried using the Bones rack, and I am returning it. Even with the hatch huggers, the straps go over the spoiler and cause it to deform (luckily it is plastic so it snapped back in shape once the rack was removed). With long term use it looks like it would do some serious damager to the spoiler. I am surprised Saris had it listed under the fit guide. It does not seem safe at all. Link to comment Share on other sites More sharing options...
rosta Posted June 17, 2005 Share Posted June 17, 2005 I wouldn't be all that surprised. You can't really believe rack companies test fit every car on the market. I suspect they used historical data with this application and will change their fit guide after hearing from unhappy consumers or shops. Link to comment Share on other sites More sharing options...
turbotaz Posted June 18, 2005 Author Share Posted June 18, 2005 In responce to my complaint they claimed they actually tried a test-fit on the vehicle. I bet they did not try to test a loaded rack and did not think that the spoiler would flex once you out the bikes on. Link to comment Share on other sites More sharing options...
mwiener2 Posted June 18, 2005 Share Posted June 18, 2005 or they one they tested didn't have the spoiler My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Edvig Posted June 20, 2005 Share Posted June 20, 2005 hmmm...that's sad. I still haven't used mine yet. Maybe I never will. Link to comment Share on other sites More sharing options...
Edvig Posted July 17, 2005 Share Posted July 17, 2005 Bump for an update. I installed my Saris Bones Rack on to my Legacy today and turbotaz is 100% correct. The Saris Bones will not work comfortably on any 05 Legacy Wagon that has the flat spoiler on the back of the car. I'm pretty sure all the new Legacys have this flat spoiler, even the Outbacks. I'll probably keep the Bones rack and use it on my WRX. Link to comment Share on other sites More sharing options...
mtnsubie Posted July 19, 2005 Share Posted July 19, 2005 Go with a roof rack. I have the moon roof also and I don't really notice it when I have the moonroof open. It does make a lot of noise though. Also, I simply take my rack off when I don't need it. It takes 5 mins is all. Link to comment Share on other sites More sharing options...
Edvig Posted July 19, 2005 Share Posted July 19, 2005 I can't decide...roof rack or hitch. Link to comment Share on other sites More sharing options...
mtnsubie Posted July 19, 2005 Share Posted July 19, 2005 Roof Rack: Can access trunk, no damage to bikes if rear-ended, a little harder for thieves to reach up to roof, can be major damage if you forget bikes/stuff are up there and drive into garage or low ceiling. Hitch/rear mount: Cannot access trunk, major rear end damage to car AND bikes, easier for thieves, easier to load bikes, no garage/ceiling clearance issues Link to comment Share on other sites More sharing options...
