PKs17 Posted July 20, 2011 Share Posted July 20, 2011 I test drove a 06 legacy gt wagon at the subaru dealer the other day. It was great, so much more responsive then my 03 wrx. Anyways, i noticed that the drivetrain had a humming noise every time i was cruising. Even just a tiny bit of throttle and the noise would be there, then as soon as i take my foot off the gas, the noise is gone. Sounds like the diffs, or tranny, but is this normal? I know for my WRX, it doesnt have this type of noise at all, it just has a super loud gear whine when engine braking. Link to comment Share on other sites More sharing options...
nm Posted July 20, 2011 Share Posted July 20, 2011 I think this is normal. It should blend in with road noise on anything but the smoothest roads. I have this, but pretty much non of my rubber bits are stock anymore, so i get a bit more NVH, so I don't know what normal is anymore. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 20, 2011 Share Posted July 20, 2011 ride in the back seat, while someone is driving the car, listen for noise from the rear diff or wheel bearings. If that's quiet you should be good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PKs17 Posted July 20, 2011 Author Share Posted July 20, 2011 Well, i can hear the humming from the drivers seat. It wasnt like a roar, but it was def noticable. Im guessing that this is just the normal drivetrain noise, but im a little weary because i dont get the same noise from my wrx, which has more NHV to begin with. Link to comment Share on other sites More sharing options...
SSpeed Posted July 20, 2011 Share Posted July 20, 2011 I'd check and see if the recall was done on the wheel bearings.... or was it just an extended warranty on them by Subaru? I think it was the latter... Link to comment Share on other sites More sharing options...
lee07 Posted July 20, 2011 Share Posted July 20, 2011 Go drive another legacy and see if it makes the same noise. Don't buy a car that the first thing you do to it is fixing it. Link to comment Share on other sites More sharing options...
PKs17 Posted July 21, 2011 Author Share Posted July 21, 2011 Yah, thats a good idea. Only problem is that particular model is very hard to find. Legacy GT wagons, with a manual tranny is very rare around here. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2011 Share Posted July 21, 2011 You must not be from the USA, we only got 5MT in our 05GT wagons. I have a Blk one. There's a list in the News of how many in which colors were made. http://legacygt.com/forums/showthread.php/official-my2005-production-numbers-model-color-83304.html Yes the tranny is loud, but still check out the rear of the car for either the diff or wheel bearings. I just replaced my rear diff at 142,000 miles. My rear bearings are still original. I have a early 05. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PKs17 Posted July 21, 2011 Author Share Posted July 21, 2011 SO is it common for the diffs to fail? The car only has 40K miles on it, and got the major service with the fluids changed at its proper interval. Link to comment Share on other sites More sharing options...
