I Donated broknindarkagain Posted July 20, 2011 I Donated Share Posted July 20, 2011 This isn't about a Legacy, but its the BD Legacy GT drivetrain (EJ25D w/ 4EAT). I'm looking at buying a 98 Impreza 2.5RS. The seller says that sometimes the transmission won't shift into second gear. If you let off the gas, then start pushing the gas again sometimes it will catch second and be perfectly normal for awhile. I'm not very knowledgeable about automatic transmissions. I've always dealt with 5 speeds. What does this sound like it could be? Dirty fluid? Clogged filter? Dirty valve body? Toasted bands? Bad trans all together? I don't mind dropping a new trans into it if I have to, but before I buy it I would like to know what I'm getting into. I'll be going to look at the car and test drive it tomorrow to see how it does. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted July 20, 2011 Share Posted July 20, 2011 Mine was starting to stick. But I did a fluid change and put an additive called trans-x in and it fixed it. Link to comment Share on other sites More sharing options...
johnegg Posted July 20, 2011 Share Posted July 20, 2011 you won't learn much if it doesn't do it on the test drive, but see how it shifts when you shift it by hand. the 4eat is designed to hold 1st when the selector is put in 1. same for 2, it starts in second and stays in second. i think the only exception being once you hit the rev limit or something like that. it is designed to shift up at a certain RPM to protect the engine / trans. if you buy it, buy it as though it needs a trans. then if you get lucky and don't need one you are ahead. generally speaking the trans in these cars are very reliable if they get serviced on a regular basis. Link to comment Share on other sites More sharing options...
johnegg Posted July 20, 2011 Share Posted July 20, 2011 one other thought to consider, look at the seller, is there a chance the car was driven hard or mistreated?? Link to comment Share on other sites More sharing options...
Baddog Posted July 20, 2011 Share Posted July 20, 2011 My car is driven hard and surprisingly the 4EAT is still intact. It is now due for new fluid but that's about it. I also did change it about 15-20k miles ago. I tested out the theory of putting it into 1st and it will bounce off the rev limiter and it will NOT up shift. Maybe it's just certain years? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2011 Author I Donated Share Posted July 20, 2011 I tested out the theory of putting it into 1st and it will bounce off the rev limiter and it will NOT up shift. Maybe it's just certain years? o_O Is your engine broken now? lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted July 20, 2011 Share Posted July 20, 2011 Lol! I've never hear of any at doing that. I though if you put it in 1st or 2nd it wont shift from that gear lol. Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2011 Author I Donated Share Posted July 20, 2011 I'm talking about when the car is in drive...it won't upshift -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
johnegg Posted July 20, 2011 Share Posted July 20, 2011 I tested out the theory of putting it into 1st and it will bounce off the rev limiter and it will NOT up shift. Maybe it's just certain years? what can i tell you, i read it online, a subaru forum no less. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2011 Author I Donated Share Posted July 20, 2011 Did it happen to be ultimate-subaru? lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted July 20, 2011 Share Posted July 20, 2011 Lol if I put it in first and rev it to redline it won't upshift John. Was responding to johneggs statement. No my engine isn't broken now. That thing takes a HELL of a beating it sees redline quite often. Almost at 180k. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2011 Author I Donated Share Posted July 20, 2011 boxer engines ftw -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
