arlia101 Posted July 19, 2011 Share Posted July 19, 2011 I've got a 1999 Legacy SUS with 116K on it, purchased it used just over a month ago. The cruise control has never worked, but I only just got to looking around enough to find something useful. I can turn it on and the light will show; playing with the toggle on the steering wheel gives me a click from inside the dash, but it does not engage; does not hold speed nor accelerate upon command. I took this video under the hood earlier today: http://youtu.be/Wk21DJySyBo Sorry for the absolutely junky quality - I had to make do with my cell phone. It should still be possible to see - basically, following the cable from the back of the CC module, I found a rubber hose just dangling - and I assume "just dangling" is not the proper configuration. Where is it supposed to go? (And yes, I've posted this on a couple of forums - seeing which one has the most useful advice on my year/model) Link to comment Share on other sites More sharing options...
johnegg Posted July 19, 2011 Share Posted July 19, 2011 does the speedo work? a bad front speed sensor will keep the cruise control from working. and maybe a bad brake pedal switch. Link to comment Share on other sites More sharing options...
arlia101 Posted July 19, 2011 Author Share Posted July 19, 2011 Speedometer seems to work fine. Don't know what I'd look for to tell if the brake pedal switch is bad; brake lights illuminate when I press it... Looking at the service manual, the dangling hose I found seems to be meant for a vacuum pump. Would that disable CC/ how does one actually reconnect it (epoxy, hose clamp...)? Link to comment Share on other sites More sharing options...
arlia101 Posted July 21, 2011 Author Share Posted July 21, 2011 Okay, easy enough - the shop manual didn't have much of a helpful picture so I had to feel around for the nipple the CC hose was detached from. I can cruise now, though I'm a little worried about why it was disconnected in the first place. Hopefully owner's choice, or accident... not as a safety measure. Link to comment Share on other sites More sharing options...
