19Legacy97 Posted July 19, 2011 Share Posted July 19, 2011 Blew the 20A subfan fuse today. Twice... Found out after temp gauge was higher than the H. The large rubber hose that connects the rad to the rest of the engine was collapsed like there was a strong vacuum. help! I've got to get it home. today yet too. I have no more extra fuses as-well. >.< Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 19, 2011 I Donated Share Posted July 19, 2011 Sounds like your waterpump went out. Get it towed. If its overheating like that, you're going to damage the heads -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
19Legacy97 Posted July 19, 2011 Author Share Posted July 19, 2011 The rad was almost empty. as being filled however it was bubbling. (slow pour) On start the coolant sucked down. but the temp just kept climbing again. Then the reservoir started spraying fluid out the over fill hole. turned off the engine and to my surprise the res was full... Like to the top... I only filled that to what the manual said too. which is way lower. The temp was 3-5 dots off the double dotted line on the heat gauge. So she was hot. and the large rad hose sucked in again. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2011 I Donated Share Posted July 20, 2011 you need to wait until its cooled all the way before you add coolant -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
19Legacy97 Posted July 20, 2011 Author Share Posted July 20, 2011 thermostat was seized. All good n cool now. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 20, 2011 I Donated Share Posted July 20, 2011 how long did you drive it overheated and how bad did you let it overheat -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
19Legacy97 Posted July 20, 2011 Author Share Posted July 20, 2011 for about a minute or two. hottest it got while driving was the two dots. When it went above the H i was on a dead road with no one on it. Neutral and shut er down. Link to comment Share on other sites More sharing options...
19Legacy97 Posted July 20, 2011 Author Share Posted July 20, 2011 coasted at 60km/h till she rolled to a stop. in her parking spot where she sat for 8 hours. It was driven home by my dad who would drive a block then let it cool. Link to comment Share on other sites More sharing options...
