benny08 Posted July 15, 2011 Share Posted July 15, 2011 Hey, i have recently bought a 1991 legacy RS. When im driving slowly, e.g in or out of a parking space or even when still. there is sometimes a loud solid one off knocking noise (just one knock) that occurs when i am turning the wheel, i have thoughts that it may be something to do with the steering rack, but im not sure. Any thoughts or suggestions on this? Thanks. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 15, 2011 Share Posted July 15, 2011 Probably the ball joint. Get underneath the front wheel and see if the boot is torn or if it'll push out any grease. If not it's shot. You can also check the outer tie rod boots while you're at it. More like a clunking noise, right? Link to comment Share on other sites More sharing options...
benny08 Posted July 15, 2011 Author Share Posted July 15, 2011 thanks ill do that. yeah its kind of between a knocking and clunking noise. also when cornering at normal driving speeds, the steering wheel will sometimes violently vibrate and shake, however this will then stop if the corner is sharp enough and i can turn the wheel further round.. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 15, 2011 Share Posted July 15, 2011 The ball joint can cause the clunk and the tie rod end can cause the shake. It could be either though. It's a simple enough job for the ball joint. I hate doing tie rod ends though. Pain trying to line them up perfectly back where they were. Link to comment Share on other sites More sharing options...
benny08 Posted July 15, 2011 Author Share Posted July 15, 2011 cheers, ill post again when i get the chance to have another look at it Link to comment Share on other sites More sharing options...
Baddog Posted July 16, 2011 Share Posted July 16, 2011 CV axles Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 17, 2011 Share Posted July 17, 2011 CV axles are more of a clicking in my experience and usually during turning. Link to comment Share on other sites More sharing options...
Baddog Posted July 17, 2011 Share Posted July 17, 2011 Then I would look at struts/springs after he looks over the ball joint. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted July 17, 2011 Share Posted July 17, 2011 Probably not a bad idea Link to comment Share on other sites More sharing options...
