W1CKED Posted July 13, 2011 Share Posted July 13, 2011 (So...I'm a little bit of a Comic Book Nerd...sue me) http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-03.jpg http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-01.jpg http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-02.jpg http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-04.jpg Putsch Racing Batmobile Specifications: Military Boeing turboshaft helicopter engine 139” wheelbase 20 ft long 7 feet, 5 inches wide 2800 lbs without driver (est) Steel tube frame/monocoque chassis Fully independent cockpit-adjustable pneumatic suspension Limited slip differential Disc brakes 4 speed sequential shift, semi-automatic transmission with reverse Digital avionics with I-Pad for app support, GPS, and satellite internet Infra-red and visible light spectrum reverse cameras with cockpit monitor Sliding canopy On board fire suppression system (The car is currently both registered and insured for the road in the United States) The Engine: The engine is a turboshaft engine created by Boeing. It was most extensively used by the US Navy to power a drone attack helicopter. The helicopter was used in the late 1960’s to drop two torpedoes up to a 70 mile radius away from a ship to protect against enemy submarines. The engine uses its jet thrust to internally propel turbine blades that spin an output shaft after going through a planetary reduction gearbox. The engine burns Jet fuel, Kerosene, or diesel. Its output of 365 hp gives the Batmobile a similar power to weight ratio as a Doge Viper. [ame=http://www.youtube.com/watch?v=nZSBpFMWk-M]YouTube - World's only actual turbine powered Batmobile[/ame] ORIGINAL STORY Link to comment Share on other sites More sharing options...
BigBlack-V Posted July 13, 2011 Share Posted July 13, 2011 wow that thing is pretty cool I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
ehsnils Posted July 13, 2011 Share Posted July 13, 2011 Only thing they are missing is the real Bat Cave. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted July 14, 2011 Share Posted July 14, 2011 It doesn't even have .50 cal Brownings mounted in the fenders. Fail. Link to comment Share on other sites More sharing options...
Knight705 Posted July 14, 2011 Share Posted July 14, 2011 one problem.... every bad guy will hear batman coming miles away from the shriek of the turbine..... Link to comment Share on other sites More sharing options...
W1CKED Posted July 14, 2011 Author Share Posted July 14, 2011 It doesn't even have .50 cal Brownings mounted in the fenders. Fail. These? http://www.kbiii.com/putschracing/wp-content/uploads/2011/05/Batmobile-900x500-e1305915287680.jpg Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted July 14, 2011 Share Posted July 14, 2011 These? http://www.kbiii.com/putschracing/wp-content/uploads/2011/05/Batmobile-900x500-e1305915287680.jpg Those are .30 cal Brownings....FAIL! Link to comment Share on other sites More sharing options...
05GT Guru Posted July 14, 2011 Share Posted July 14, 2011 Its got alot of blind spots All you have to do is get next to it or behind it to get away Link to comment Share on other sites More sharing options...
ehsnils Posted July 14, 2011 Share Posted July 14, 2011 one problem.... every bad guy will hear batman coming miles away from the shriek of the turbine..... But it will be a great preventive action since you will scare away all criminals for several blocks. Link to comment Share on other sites More sharing options...
W1CKED Posted July 15, 2011 Author Share Posted July 15, 2011 Here's his V8 version with "working" machine guns: [ame=http://www.youtube.com/watch?v=SMgp4MVEOds]1989 Batmobile Replica - YouTube[/ame] Link to comment Share on other sites More sharing options...
