A "REAL" Turbine-Powered 1989 Batmobile
(So...I'm a little bit of a Comic Book Nerd...sue me)
http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-03.jpg
http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-01.jpg
http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-02.jpg
http://www.toddcooperider.com/wp-content/uploads/2011/07/turbine-powered-batmobile-04.jpg
Putsch Racing Batmobile Specifications:
Military Boeing turboshaft helicopter engine
139” wheelbase
20 ft long
7 feet, 5 inches wide
2800 lbs without driver (est)
Steel tube frame/monocoque chassis
Fully independent cockpit-adjustable pneumatic suspension
Limited slip differential
Disc brakes
4 speed sequential shift, semi-automatic transmission with reverse
Digital avionics with I-Pad for app support, GPS, and satellite internet
Infra-red and visible light spectrum reverse cameras with cockpit monitor
Sliding canopy
On board fire suppression system
(The car is currently both registered and insured for the road in the United States)
The Engine:
The engine is a turboshaft engine created by Boeing. It was most extensively used by the US Navy to power a drone attack helicopter. The helicopter was used in the late 1960’s to drop two torpedoes up to a 70 mile radius away from a ship to protect against enemy submarines. The engine uses its jet thrust to internally propel turbine blades that spin an output shaft after going through a planetary reduction gearbox. The engine burns Jet fuel, Kerosene, or diesel. Its output of 365 hp gives the Batmobile a similar power to weight ratio as a Doge Viper.
[ame=http://www.youtube.com/watch?v=nZSBpFMWk-M]YouTube - ‪World's only actual turbine powered Batmobile‬‏[/ame]
ORIGINAL STORY
one problem.... every bad guy will hear batman coming miles away from the shriek of the turbine.....
But it will be a great preventive action since you will scare away all criminals for several blocks. :D
