BIGAL8899 Posted July 13, 2011 Share Posted July 13, 2011 the other day my leggy was getting 21.5 mpg, then i changed the oil with that royal purp and then it went down to 18.5. Then today it went up to 19.5. Is this normal?Thoughts? Link to comment Share on other sites More sharing options...
AShoe Posted July 13, 2011 Share Posted July 13, 2011 Yep. Royal purple will ruin your engine!! The fuel consumption meter is fairly inaccurate. It's probably a combination of your right foot and some dirty gas. Link to comment Share on other sites More sharing options...
BIGAL8899 Posted July 13, 2011 Author Share Posted July 13, 2011 Yep. Royal purple will ruin your engine!! The fuel consumption meter is fairly inaccurate. It's probably a combination of your right foot and some dirty gas. why r u saying that about my purp? Link to comment Share on other sites More sharing options...
Heedz Posted July 15, 2011 Share Posted July 15, 2011 did you fill up in between. ive had times where i cannot get above 18 and the car runs like shit. Link to comment Share on other sites More sharing options...
BIGAL8899 Posted July 16, 2011 Author Share Posted July 16, 2011 no it was at half tank when i changed the oil Link to comment Share on other sites More sharing options...
-TT- Posted July 16, 2011 Share Posted July 16, 2011 why r u saying that about my purp? http://imageftw.com/uploads/20110716/purpledrank.jpg Link to comment Share on other sites More sharing options...
mikeislord Posted July 16, 2011 Share Posted July 16, 2011 Johnson rod is probably mis-aligned. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted July 16, 2011 Share Posted July 16, 2011 no it was at half tank when i changed the oil well that's your problem right there. royal purple specifies for all subaru 2.5 liter turbo engines you need to change your oil with a full tank to get rid of the excessive gasoline fumes Link to comment Share on other sites More sharing options...
mikeislord Posted July 16, 2011 Share Posted July 16, 2011 well that's your problem right there. royal purple specifies for all subaru 2.5 liter turbo engines you need to change your oil with a full tank to get rid of the excessive gasoline fumes Perhaps the fuel tap discharge vent is loose? I'd check that, drive another 100 miles then check it again. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted July 16, 2011 Share Posted July 16, 2011 ^hmm possibly... op is your car throwing a ID 10T cel? Link to comment Share on other sites More sharing options...
BIGAL8899 Posted July 17, 2011 Author Share Posted July 17, 2011 well that's your problem right there. royal purple specifies for all subaru 2.5 liter turbo engines you need to change your oil with a full tank to get rid of the excessive gasoline fumes didnt kno that , its at 20.7 now , but it should be slightly higher Link to comment Share on other sites More sharing options...
mikeislord Posted July 17, 2011 Share Posted July 17, 2011 ^hmm possibly... op is your car throwing a ID 10T cel? An ID 10T cel is for fuel filter not oil filter, you jackass. But in either case, if the transhift coil voltage ID is below 89.3, it could throw a cel. Link to comment Share on other sites More sharing options...
bmx045 Posted July 17, 2011 Share Posted July 17, 2011 royal purple oil has transilluminant chemicals in it that worsen gas milage until the oil is 'broken in'. So you need to drive it for a bit before the oil thins out and lubricates better, right now it's slowing your engine down causing excess gas consumption. Glad to be of service Link to comment Share on other sites More sharing options...
LegGTLT Posted July 17, 2011 Share Posted July 17, 2011 Always make sure that you check the projector headlight fluid when you change the engine oil. Trans oil can be left alone for 100k mile intervals but gear oil must be done every other engine oil change but not when you're at a major 30k interval service. Just a heads up. Please PM joeleodee For All Site Questions. He is the acting Admin and can resolve anything related to LegacyGT.com Link to comment Share on other sites More sharing options...
LGT For ME Posted July 19, 2011 Share Posted July 19, 2011 great advise I had the same problem a few months ago and the headlight fluid change cured it real quick. now I'm gettin 28.8mpg on e85, I'm stoked Link to comment Share on other sites More sharing options...
BIGAL8899 Posted July 20, 2011 Author Share Posted July 20, 2011 Always make sure that you check the projector headlight fluid when you change the engine oil. Trans oil can be left alone for 100k mile intervals but gear oil must be done every other engine oil change but not when you're at a major 30k interval service. Just a heads up. I have no idea what ur talkin about, plz explain Link to comment Share on other sites More sharing options...
bmx045 Posted July 20, 2011 Share Posted July 20, 2011 I have no idea what ur talkin about, plz explain If you take the caps off the back of the headlights you will see a small fill tube, it should be topped off with subaru headlight fluid/lubricant in order for the low beam bulbs to operate smoothly. The bulbs can rust and wear out if there isn't any fluid in there, also causing ignition problems as well...thus poor fuel economy. Link to comment Share on other sites More sharing options...
grecod Posted July 20, 2011 Share Posted July 20, 2011 Get a left handed screw driver and a bucket of steam, floor it and drive top speed at an cliff with a 100 plus foot drop off and viola..problem solved. Link to comment Share on other sites More sharing options...
bmx045 Posted July 20, 2011 Share Posted July 20, 2011 Get a left handed screw driver and a bucket of steam, floor it and drive top speed at an cliff with a 100 plus foot drop off and viola..problem solved. Now now. The OP deserves to be helped, not haggled. My solution is far more practical. Link to comment Share on other sites More sharing options...
BIGAL8899 Posted July 20, 2011 Author Share Posted July 20, 2011 If you take the caps off the back of the headlights you will see a small fill tube, it should be topped off with subaru headlight fluid/lubricant in order for the low beam bulbs to operate smoothly. The bulbs can rust and wear out if there isn't any fluid in there, also causing ignition problems as well...thus poor fuel economy. Really? I had no idea. Is this fluid expensive? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted July 20, 2011 Share Posted July 20, 2011 ^There's all different kinds. If you use something synthetic with a high boiling point to increase the bulb effectiveness, you could spend about $65 a bottle. Link to comment Share on other sites More sharing options...
joeblow Posted July 20, 2011 Share Posted July 20, 2011 But he has a spec.B so he actually needs purified unicorn tears for the headlight fluid reservoir. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
Nrw Posted July 20, 2011 Share Posted July 20, 2011 Get a left handed screw driver and a bucket of steam, floor it and drive top speed at an cliff with a 100 plus foot drop off and viola..problem solved. Wow everyone else is trying to be helpful. And you come in like this? That's messed up. Link to comment Share on other sites More sharing options...
SSpeed Posted July 20, 2011 Share Posted July 20, 2011 Really? I had no idea. Is this fluid expensive? Only if you get the Royal Purple headlight fluid is it expensive... I personally use Valvoline, after all, they were the only fluid warrantied for the Lamborghini Countach. Most places will also claim not to have the fluid because auto parts clerks are idiots and don't know what they stock or what it's used for, you just have to keep asking around. Link to comment Share on other sites More sharing options...
bmx045 Posted July 20, 2011 Share Posted July 20, 2011 Really? I had no idea. Is this fluid expensive? some autoparts stores or chains might laugh and not know what you're talking about, just tell the dealer you need the synthetic headlight fluid for the Spec B and they will hook you up. There's a lotta haters out there that just don't know what they're talking about Link to comment Share on other sites More sharing options...
