OkieSmokie Posted July 8, 2011 Share Posted July 8, 2011 I swear on all things holy that I searched prior to posting:hide:. I've been having issues with my moonroof for the past couple days and thought you guys and gals might be able to help. When I go to open the front half - tilt it up that is, the passenger side will not open. The driver side pops up, but there is no travel in the sliding glass as the railing can't clear with the passenger side still down. Now, add to this that one of the rubber seals has broken loose and is currently located in my passenger seat. I believe the seal rests between the 2 pieces of glass so I doubt there is an issue there beyond something cosmetic. Has anyone had a similar issue? What's the best way to attach this thing? It is packaged pretty tightly. I'm tempted to remove the front glass just to get at it, but I thought I'd give a shout to the LGT community before getting all agro on it. Thanks for your help! Link to comment Share on other sites More sharing options...
Max Capacity Posted July 9, 2011 Share Posted July 9, 2011 Find a body shop that can fix it, Don't go to the Stealership. Most good Body Shop should know how to fix your issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
