markyerger Posted July 7, 2011 Share Posted July 7, 2011 I have had my Sirius Sportster for well over 5 years, and her reception (acquiring signal) has bit the dust. And yes, I even installed new rooftop antennas. I have a Sirius Starmate that I installed in the Legacy to replace the old Sportster. My problem is the static from the terrestrial stations interferes with the satellite reception using the FM transmitter. I have tried ALL the preset stations, they all stink. I would like to run the wires into the back of the radio for AUDIO IN. But before I open the center console up and remove the radio, I want to make sure that there is actually an AUDIO IN on the back of my factory radio. I 've looked everywhere and cannot find the answer. Anyone here?? Link to comment Share on other sites More sharing options...
AdAstra Posted July 7, 2011 Share Posted July 7, 2011 This might be of interest: http://legacygt.com/forums/showthread.php/leptronix-aux-115605.html Link to comment Share on other sites More sharing options...
Max Capacity Posted July 7, 2011 Share Posted July 7, 2011 When I installed the factory Sat kit in my 09, I did notice one other connector on the back of the radio that was not being used. HAve you looked through the audio forum ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
