valkrie hunter Posted June 28, 2011 Share Posted June 28, 2011 So, I had a pair of D1S (from Cadillac CTS) OEM looking to be retrofitted. I finally took apart one of my headlights to get the new eyes in. Here's a little progress thread for my build. Here I already took apart the headlights, and started to compare projectors: http://i11.photobucket.com/albums/a155/ValkrieHunter/Retrofit/IMG_0121.jpg http://i11.photobucket.com/albums/a155/ValkrieHunter/Retrofit/IMG_0123.jpg Here is the stock metal plate that I planned to modify to hold the D1S projectors because they were different. http://i11.photobucket.com/albums/a155/ValkrieHunter/Retrofit/IMG_0124.jpg After cutting up the plate, I found a bit of alighnment problem in the plate/projector. it sits a bit too much forward compared to the stock projectors. The projector were also sitting a bit too much to the bottom left. I'll be fixing those. http://i11.photobucket.com/albums/a155/ValkrieHunter/Retrofit/IMG_0126.jpg http://i11.photobucket.com/albums/a155/ValkrieHunter/Retrofit/IMG_0127.jpg http://i11.photobucket.com/albums/a155/ValkrieHunter/Retrofit/IMG_0128.jpg *While taking apart the headlight, i discovered when I had recieved the headlights with broken tabs on the silver housing(or maybe i broke them when taking it apart, but i didn't hear any breaks or cracks when taking the lens off) Is there any way i could reglue (epoxy or superglue?) to broken tabs... or would it be better if i replaced it with a nonbroken housing? Thanks! Will try to keep this updated. If there's any suggestion, feel free to share! This IS my first time doing a retrofit, so bear with me. Link to comment Share on other sites More sharing options...
brownmutthid Posted June 29, 2011 Share Posted June 29, 2011 To be honest not sure what silver tabs you are referring too but if I have any plastic breaks it usually ends up that I replace the whole unit...I have yet to find a plastic adhesive/epoxy that actually works well with these harder plastics... Otherwise though it looks like your idea worked out pretty well...just a little adjustment required. I sometimes wish my car had factory projectors... Link to comment Share on other sites More sharing options...
