that97lgt Posted June 24, 2011 Share Posted June 24, 2011 hello all been a while since last post be busy fun rebuild on my gt new parts pistons, lifters, sleeves, cams, throttle spacer, knock of borella headers, ngk plugs wires, royal purple full synth. so much more to list without invioce. had a question about doing no cats just straigh pipe back to stock muffler has anybody done or tried this. i am tryin to get options for next thing onlist sry for long post btw build 2.5's are soooo much fun Link to comment Share on other sites More sharing options...
Lookatmyrust Posted June 25, 2011 Share Posted June 25, 2011 yea just run straight pipe and tap them for the o2 sensors. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 25, 2011 I Donated Share Posted June 25, 2011 yea just run straight pipe and tap them for the o2 sensors. you will throw a code for "catalyst efficency below threshold" if you do that. why on earth do you want to remove your cats and keep a stock muffler. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
that97lgt Posted June 25, 2011 Author Share Posted June 25, 2011 low profile cops love gettin pple for loud exhuast in my area. had a modified spt but it was stolen prior to build. Link to comment Share on other sites More sharing options...
johnegg Posted June 25, 2011 Share Posted June 25, 2011 there is a spacer trick you can use on the rear o2 sensor to ''fool'' the computer into thinking the cats are still there. i haven't tried it but i here it works. you get the correct size spark plug anti-fouler (correct for the o2 sensor, not the spark plug) and drill out the center so it will thread on to the o2 sensor. then thread the combo into the o2 spot. the spacer moves the sensor further out of the main flow and it becomes less sensitive and more forgiving. in extreme cases you can add a second anti-fouler to the first, ''un-drilled''. this will put the o2 in a very small world of it's own. but i hear the second one usually isn't necessary. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted June 25, 2011 Share Posted June 25, 2011 hmm. the shop i have do this may not wanna deal with that. i barely under stand it. are there pictures. basicallly how far are you moving the o2 senor out from the pipe? i just have the shop add extra metal to the spot on the pipe. and tap it. and use washers to move the sensor up and down? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted June 25, 2011 Share Posted June 25, 2011 http://www.vexmotorsports.com/BLOX-CEL-Check-Engine-Light-Eliminator-Adapter_p_428.html do they make this for a subaru? edit got this? but it says only for rear.. what about front. http://www.rallitek.com/RalliTEK-O2-Sensor-Spacer/p-4419 Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 26, 2011 I Donated Share Posted June 26, 2011 you dont want to use a spacer on the front....it will make you run rich as hell. only put it on the rear. do a search on rs25.com. iirc, there is like a 20 page thread about o2 spacers. you could just make a simulator with resistors and whatnot from radio shack that will make the computer think the o2 is getting proper readings fyi when refering to o2s front = upstream rear = downstream -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
