PartyRock Posted June 24, 2011 Share Posted June 24, 2011 This may be a dumb question, but that's okay because I'm dumb. My friend has an 09 wrx and 05 wrx with BC coilovers and stock sway bars on both, they handle on rails and barely sway, do you think you could get away with using bc coilovers on a stiff (obv damper not spring rate) setting and no sway bars? Just a thought and was wondering if anyone tried this....and yes I know the legacy is heavier than the wrx Link to comment Share on other sites More sharing options...
joeblow Posted June 24, 2011 Share Posted June 24, 2011 Whitetiger is running without a front sway bar on a coilover setup. Hopefully he chimes in and can give you more info about it. Or you can shoot him a pm. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
StoplightAssassin Posted June 24, 2011 Share Posted June 24, 2011 You'll be fine. I ran my car with COs and stock sways for awhile. I eventually upgraded the sways and endlinks, because I wasn't happy with the amount the car still rolled. Link to comment Share on other sites More sharing options...
Nrw Posted June 24, 2011 Share Posted June 24, 2011 You can do it with stiff coilovers. That's how the people had to do it with my last car, maxima. No one made a replacement front bar and the rear bars people would add on would cause binding in the rear suspension. Link to comment Share on other sites More sharing options...
whitetiger Posted June 24, 2011 Share Posted June 24, 2011 Whitetiger is running without a front sway bar on a coilover setup. Hopefully he chimes in and can give you more info about it. Or you can shoot him a pm. Chime! yes, i have no front bar, and stock rear bar. But i also have 11.5K front / 12.5K rear spring rates (with proper dampening from AST 4100 dampers). My car has less roll than my old tein flex setup (8k/9k rates) with 25mm bars F/R and it rides better too. better to control roll with springs/struts anyways than have bars that remove suspension independence. Link to comment Share on other sites More sharing options...
Beanboy Posted June 24, 2011 Share Posted June 24, 2011 I have stock bars, JDM Bilstein take-offs. Biggest issue for me was the dive and squat followed by the crap rebound control. <--- Better all-around now. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
PartyRock Posted June 24, 2011 Author Share Posted June 24, 2011 Well I already have rallitek bars and springs since my car came with them from the PO. It's a harsh ride on stock struts which got me thinking about CO's, then i remembered how my friend's car drove with them. I like the idea that you eliminate the whole bar and endlinks all together- less parts, less worry about clunks and squeaks lol. I had a jeep once and completely removed the front and rear sways and it drove SO much better over bumps- however not so safe on the highway. Whitetiger, any idea what the bias would be without bars? Probably oversteer eh? Link to comment Share on other sites More sharing options...
whitetiger Posted June 24, 2011 Share Posted June 24, 2011 depends on your spring rates. removing bars also increases your grip limit for uber traction. fyi, i do not recommend taking your bars out unless you have significantly increased your spring rates. no aftermarket "lowering" bolt on spring will be stiff enough. id only consider this if you have coilovers with stiffer spring rates to compensate for the lack of roll bars. my springs and dampers now are so sitff that i lift the front inside wheel when cornering. removing the front sway keeps both wheels on the ground and lets me use my front LSD to its intended purpose. Link to comment Share on other sites More sharing options...
PartyRock Posted June 24, 2011 Author Share Posted June 24, 2011 hmmmmm. well in the future i do plan to get coilovers- i figure these bars plus coilovers may be a bit rough combined for a daily city driver. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted June 24, 2011 Share Posted June 24, 2011 FWIW going to larger wheels and summer tires had more detrimental effects to my car's ride than adding COs or sways. My car feels luxurious when I switch back to my winter wheels/tires, which are just a tad wider than stock GTs. Link to comment Share on other sites More sharing options...
