18x8 with a +51 offset w/ Eibachs?
SlickSpur
Will this fit? I'm looking at some 18" Superleggeras. I have the Eibach Pro Kit on my car, factory struts. The seller says the wheels are 18x8 with a +51 offset. Will I need to roll my fenders or anything? I'd really prefer to buy wheels that don't require modification.
Whoops, they're 215/45/18 RE92a's.
Not sure how to read this
http://www.willtheyfit.com/wheelimage.php?tyrediameter=625.3&tyrewidth=215&tyrecirc=1964.437884045&wheelwidth=177.8&wheeldia=431.8&offset=55&poke=33.9&inset=143.9&aspect=45&tyrediameter2=650.7&tyrewidth2=215&tyrecirc2=2044.234337355&wheelwidth2=203.2&wheeldia2=457.2&offset2=51&poke2=50.6&inset2=152.6&aspect2=45
Old New
Diameter 625.3mm 650.7mm
Circumference 1964.4mm 2044.2mm
Poke 33.9mm 50.6mm
Inset 143.9mm 152.6mm
Speedo error 0% -3.9%
Reading at 30mph 30mph 28.83mph
Reading at 60mph 60mph 57.66mph
Ride height gain 0mm 12.7mm
Arch gap loss 0mm 12.7mm
I believe 215/45/17 is the stock re92 size. I pulled it from the FAQ sticky thread.
The tire size is the ones that are on them now, I was looking at buying these used from a local seller. I think there isn't much tread left on the tires, so I could certainly go for something thinner walled but I'd be stuck with the ones on it for a few months.
245/35/18's on a +51 seems perfect.
What are you using now?
The tires on the wheels are 215/45/18 RE92as, not 245/35/18s, that's why I'm curious on the fit (especially lowered on Eibachs).
I'm using the stock 17"s with the stock RE92s right now (215/45/17)
fyi, i ran 245/35/18 r-comp tires(usually come wider then standard tires of the same size) on a +51 ssr rim with coilovers. it cleared the inside and cleared the unrolled fender on the outside.
what was the width on this rim?
what are your thoughts on 18x8.5 +48 offset, with 255/35/18. coilovers and rolled fenders, fronts are pulled as well...
