MasAyinde Posted June 23, 2011 Share Posted June 23, 2011 So I'm still touching up my stage 1 map, and I seem to be always pulling timing between 1.1 and 1.95 load and between 2400 and 3600 rpm. There is knocking there in the last few revisions I have made (14th or 15th) When I look back at the logs, I had hit all of those cells on the second revision of this tune and there was no knock. Now, I noticed the A/F learning was off a couple weeks ago so I checked and saw that the air filter had not been replaced, which means that the 90k service was not done. This means the spark plugs weren't changed. I will change them, but can old spark plugs have this effect on knock? I don't know if I should flash back to an older revision with more aggressive timing after I change my plugs or if I should keep pulling timing little by little with the current revision. Any thoughts? Link to comment Share on other sites More sharing options...
NSFW Posted June 24, 2011 Share Posted June 24, 2011 I don't know if spark plugs will affect knock. But it might help if you set your CL/OL delays to zero - that will cause the AFR to richen up more quickly when you transition from cruise to boost, and that's probably what's happening when you're the RPM/Load range that you're talking about. Link to comment Share on other sites More sharing options...
keithk831 Posted June 24, 2011 Share Posted June 24, 2011 Be careful. If your learning view looks anything like this (taken from my friend's car a little over a week ago), you could have a burnt valve. Link to comment Share on other sites More sharing options...
MasAyinde Posted June 24, 2011 Author Share Posted June 24, 2011 No, doesn't look anything like that. I have all zeroes except for -1.4 in a few cells around the range i talked about earlier. It's been that way for the last 6-7 revisions Link to comment Share on other sites More sharing options...
keithk831 Posted June 24, 2011 Share Posted June 24, 2011 Are you tuning your car, or is someone tuning it for you? I suggest you replace your plugs now, then work on your timing table again. Airflow can affect knock, so make sure that's good for a while before you go crazy with the timing table as well. Link to comment Share on other sites More sharing options...
