SilentOne Posted June 23, 2011 Share Posted June 23, 2011 Hello- I just bought my 06' LGT and want to reflash the ECU. I've been looking into COBB access ports and have some questions about the criteria to be met for the Stage 2 reflash/map. One of the requirements to be met is a turboback exhaust. If anyone could describe the type of exhaust I would need to reflash without running into any extreme problems that would be awesome. I've been thinking about purchasing a Magnaflow full exhuast kit, but I'm not sure if that falls into the "turboback" type of exhaust. I'm obviously not too much of a gearhead at this point, but I will be soon. Just need a fast whip, just in case ;-) P.S. if someone does have an 06' LGT 5EAT access port for sale and have some advise, maybe we could help eachother out. Thank you Link to comment Share on other sites More sharing options...
blongo804 Posted June 23, 2011 Share Posted June 23, 2011 A turboback exhaust is an aftermarket exhaust starting from the turbo back. A great downpipe (the pipe coming off the turbo) for the money would be one by CNT Racing. Here's a link to that: http://legacygt.com/forums/showthread.php/cnt-5eat-catted-down-pipes-and-mt-catted-down-pipes-161554.html Now for stage 2, technically you don't need a catback (probably the Magnaflow system you speak of is a catback) but if you'd like a nice added tone to the car, go for it! Personally, when I went stage 2, we did catless uppipe, catted downpipe, and an aftermarket catback exhaust. This should give you a good starting point. Any more questions, feel free to ask or use the search function! Link to comment Share on other sites More sharing options...
Low Drag Posted June 23, 2011 Share Posted June 23, 2011 Other good exhausts out there are Megan, Perrin, Cobb, Invidia, Borla and Gt Spec. Most should be 3-4in which is standard for most turbo cars. 2.5in usually indicates a N/A (naturally aspirated) = non-turbo car. Price ranges will definetly vary for new parts but watch the forums because you can usually save 200-400 if you don't mind going with used parts. Hope this helps. Link to comment Share on other sites More sharing options...
subiedad51 Posted June 23, 2011 Share Posted June 23, 2011 Congrats on the purchase. For a Stage 2 Map on an 06 Legacy and you need to get a Catless UP and remove one catalytic converter from your downpipe. You don't need a full exhaust for Stage 2. So - look for a catless UP and Downpipe on the classifieds (saves money) or remove your OEM ones and remove the catalytic converters yourself and put them back on. The full tuboback will free up some WHP but the UP/DOWN will give you the biggest bang. Link to comment Share on other sites More sharing options...
xcitebike Posted June 24, 2011 Share Posted June 24, 2011 The only requirement to go stage 2 with a Cobb AP is an aftermarket downpipe, whether it is catless or has high flow cats. everything else can remain stock (including the exhaust), but an aftermarket exhaust would be nice to have. Link to comment Share on other sites More sharing options...
iNVAR Posted June 24, 2011 Share Posted June 24, 2011 An UP isn't necessary, but highly recommended. Same thing with the TMIC. Either get a new aftermarket TMIC OR JB Weld (or reinforce some other way) your stock plastic TMIC. Link to comment Share on other sites More sharing options...
johnAWD Posted June 24, 2011 Share Posted June 24, 2011 FWIW I ran a stage 2 map with nothing more than a catback exhaust. Car ran fine. Link to comment Share on other sites More sharing options...
W1CKED Posted June 24, 2011 Share Posted June 24, 2011 Did I miss something? Where are the parts for sale? Link to comment Share on other sites More sharing options...
SilentOne Posted June 24, 2011 Author Share Posted June 24, 2011 no parts for sale, just asking for advice buddy! :-) Link to comment Share on other sites More sharing options...
MatsuDano Posted June 24, 2011 Share Posted June 24, 2011 ...in the classifieds section...? Link to comment Share on other sites More sharing options...
Mickeytl Posted June 24, 2011 Share Posted June 24, 2011 This thread should be moved...for sale section only Link to comment Share on other sites More sharing options...
SilentOne Posted June 24, 2011 Author Share Posted June 24, 2011 How would I go about re-designating the thread, homies? Link to comment Share on other sites More sharing options...
iNVAR Posted June 24, 2011 Share Posted June 24, 2011 You don't. Gotta wait for or contact a moderator. Also, I'll respond to your PM momentarily. Link to comment Share on other sites More sharing options...
SBT Posted June 25, 2011 Share Posted June 25, 2011 Moved to Tuning Forum. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
TPLGT Posted June 25, 2011 Share Posted June 25, 2011 A catless DP and UP with the stage 2 tune will change things...alot! You can buy a v1 Accessport for cheap or a little more ching for the V2. Consider upgradung the tune at somepoint. GL. Let us know how it goes. Rehab is for quitters. Link to comment Share on other sites More sharing options...
SilentOne Posted June 27, 2011 Author Share Posted June 27, 2011 thanks guys, sorry for the confusion on the designation of this thread.... was kindof in a rush here at work and it didn't even cross my mind. TPLGT- thanks for the advice, what is the difference between a v1 AP and a v2 AP? Also- when you say upgarding the tune as well, what do you mean by this? Should I have someone who REALLY knows what they are doing do this? Or is this a process a beginer could do- without expensive mistakes? Thanks again!! Link to comment Share on other sites More sharing options...
rock2534 Posted June 27, 2011 Share Posted June 27, 2011 thanks guys, sorry for the confusion on the designation of this thread.... was kindof in a rush here at work and it didn't even cross my mind. TPLGT- thanks for the advice, what is the difference between a v1 AP and a v2 AP? Also- when you say upgarding the tune as well, what do you mean by this? Should I have someone who REALLY knows what they are doing do this? Or is this a process a beginer could do- without expensive mistakes? Thanks again!! v2 has a better display and additional functionality, I can't speak to it too much as I never owned either! The v1 will work since you have an 06. Upgrading the tune he probably meant having a custom tune made for the AP instead of using their canned maps. And YES, have somone who knows what they are doing(Infamous) create a map for you, the map essentially is the brains of your engine. Link to comment Share on other sites More sharing options...
iNVAR Posted June 27, 2011 Share Posted June 27, 2011 A catless DP and UP with the stage 2 tune will change things...alot! You can buy a v1 Accessport for cheap or a little more ching for the V2. Consider upgradung the tune at somepoint. GL. Let us know how it goes. QFT. HUGE difference going from stock to stage 2. Even from stage 1 to 2 was an enormous upgrade. Link to comment Share on other sites More sharing options...
TPLGT Posted June 28, 2011 Share Posted June 28, 2011 v2 has a better display and additional functionality, I can't speak to it too much as I never owned either! The v1 will work since you have an 06. Upgrading the tune he probably meant having a custom tune made for the AP instead of using their canned maps. And YES, have somone who knows what they are doing(Infamous) create a map for you, the map essentially is the brains of your engine. ^^^ What he said. The V1 is specific to the transmission and model year so it may be more difficult to find one. The V2 is probably the way to go... Another tune would be reccomended as it would be specicifc for your car...Infamous is great. Lots people have had great success with him. I have used PDX in the past and like them. once you go Stage 2 look at upgrading to a reinforced TMIC...better cooling and stronger to handle the extra boost. Rehab is for quitters. Link to comment Share on other sites More sharing options...
SilentOne Posted June 28, 2011 Author Share Posted June 28, 2011 Thanks guys- you all have great comments! If you have anything more to add, please do! Link to comment Share on other sites More sharing options...
Doc-legacy2006GT Posted May 8, 2013 Share Posted May 8, 2013 dose anyone have mapes for the cobb access port for the e85 fuel Link to comment Share on other sites More sharing options...
