PartyRock Posted June 23, 2011 Share Posted June 23, 2011 My idle is set to 725 at the moment, on this particular map.... If i want to change it which idle target do i change it in? A? B? And what columns, the two on the right where it already shows 725? Thanks Link to comment Share on other sites More sharing options...
PartyRock Posted June 23, 2011 Author Share Posted June 23, 2011 Reason I ask is because if i come to an abrupt stop the rpms will drop low for a second then come back up. As far as LV says, my af's are within +-5 for all ranges. Link to comment Share on other sites More sharing options...
MasAyinde Posted June 23, 2011 Share Posted June 23, 2011 Did you reflash recently? That happens to me for about an hour after a reflash. I HOPE its normal. Link to comment Share on other sites More sharing options...
PartyRock Posted June 23, 2011 Author Share Posted June 23, 2011 No, your experiencing the relearn process after a flash. I just think the idle would smooth out if it was a tad higher Link to comment Share on other sites More sharing options...
MasAyinde Posted June 23, 2011 Share Posted June 23, 2011 So I take it you're not coming off of a recent flash. Weird that the rpm would drop like that without a vacuum leak, which I think would be picked up by the AF learning Link to comment Share on other sites More sharing options...
PartyRock Posted June 23, 2011 Author Share Posted June 23, 2011 No its very slight, barely noticable, it could be the fmic pipes just making it feel rough from vibes. This is after the relearn. Link to comment Share on other sites More sharing options...
