PearlBlueGT Posted June 18, 2011 Share Posted June 18, 2011 On startup engine is ticking like valve tapping. After a few seconds most of the noise goes away but still theres a bit present. We put new heads on there, new banjo bolts, 5w-30 Castrol syntec oil/napa gold oil filter. Car runs great except for that noise. Of course there's P0011 and P0021 codes but I've changed OCV valves from Fred Beans:confused: Link to comment Share on other sites More sharing options...
ShadowImg Posted June 18, 2011 Share Posted June 18, 2011 Ticking on the EJ20/EJ25 series engines is quite normal. Not sure if that's what you're asking? Link to comment Share on other sites More sharing options...
frank_ster Posted June 19, 2011 Share Posted June 19, 2011 they all make noise . don't worrie about it .. when it stops making noises then you should be worried! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 19, 2011 Author Share Posted June 19, 2011 Ya, it ticks a bit loud. Almost like there's no oil or something Link to comment Share on other sites More sharing options...
lowwill Posted June 19, 2011 Share Posted June 19, 2011 Worried me a bit too. Seems louder when not using synthetic oil. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted June 19, 2011 Author Share Posted June 19, 2011 Engine just blew today. Been driving home, it started making rod noise and then it just stalled on me.... Link to comment Share on other sites More sharing options...
3line Posted June 19, 2011 Share Posted June 19, 2011 Damm, sry to hear that about your engine, I was wondering the same with my JDM 07 LGT but it seems normal with EJ engines. Link to comment Share on other sites More sharing options...
doccrowley Posted June 19, 2011 Share Posted June 19, 2011 Mine was ticking after I crushed my oil pan and drove it home on a cracked Oil pickup tube. Was told it was a typical noisy Subie valve train even though I knew it was louder after the oil pan. 6 months later I have a bad intake valve #4 and low compression on the same cylinder. I'll find out tomorrow how extensive the damage is and whether I've got a valve job coming or a full motor. Best of luck with yours. I recommend a leakdown and compression tests if your valve train becomes noisier than ever. Link to comment Share on other sites More sharing options...
ShadowImg Posted June 19, 2011 Share Posted June 19, 2011 Fair point, while ticking is normal, if it changes in speed/volume/etc, it's a bad sign. Curious to hear what happened to the OP's motor. Maybe wasn't so much ticking as knocking? Link to comment Share on other sites More sharing options...
jagcars26 Posted June 19, 2011 Share Posted June 19, 2011 Fair point, while ticking is normal, if it changes in speed/volume/etc, it's a bad sign. Maybe wasn't so much ticking as knocking? I'm thinking the same,it had to be MUCH louder then the normal ticking at startup that we are all used to . Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 20, 2011 Share Posted June 20, 2011 Can someone post an HD quality audio recording of a 'normal' ticking from their engine? I am curious to find out what 'normal' ticking sounds like so I can know (kinna) for sure my somewhat quiet but noticeable ticking is also normal. That'd be great. Link to comment Share on other sites More sharing options...
jproy12 Posted June 21, 2011 Share Posted June 21, 2011 Can someone post an HD quality audio recording of a 'normal' ticking from their engine? I am curious to find out what 'normal' ticking sounds like so I can know (kinna) for sure my somewhat quiet but noticeable ticking is also normal. That'd be great. +1! I'd also like to hear!! JP Link to comment Share on other sites More sharing options...
BIGAL8899 Posted June 23, 2011 Share Posted June 23, 2011 Can someone post an HD quality audio recording of a 'normal' ticking from their engine? I am curious to find out what 'normal' ticking sounds like so I can know (kinna) for sure my somewhat quiet but noticeable ticking is also normal. That'd be great. great question, someone lets us kno!!!! Link to comment Share on other sites More sharing options...
IDRVSLO Posted June 23, 2011 Share Posted June 23, 2011 I will go give it a shot.....no pun intended. EDIT: Got some good video/sound, uploading to Youtube and posting links here. [ Link to comment Share on other sites More sharing options...
IDRVSLO Posted June 23, 2011 Share Posted June 23, 2011 Okay first video is a cold start, the car had been sitting for 24+hrs. If anyone is wondering I use Royal Purple 5w-30. I thought I saw an oil debate with noise starting above. Cold start, high idle conditions. [ame=http://www.youtube.com/watch?v=DdzG_6e-e8M]YouTube - Legacy GT Engine Start Up High Idle[/ame] Standard idle [ame=http://www.youtube.com/watch?v=kniQ7agYfsA]YouTube - Legacy GT Engine Start Up Standard Idle[/ame] [ Link to comment Share on other sites More sharing options...
SurlyOldManMN Posted June 23, 2011 Share Posted June 23, 2011 Rad, I just started researching this myself because it's really starting to bother me. Also seems to be louder after the TBE. Sounds very much like those clips. That makes me less nervous, I wanted to be sure before I bother with a more aggressive tune. Might take it in to the dealer on the way home and just ask them to take a listen anyway. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 23, 2011 Share Posted June 23, 2011 Mine sounds about the same as well, maybe a tad quieter. really a tad though..Thanks a lot for your post. Appreciate it. Link to comment Share on other sites More sharing options...
bronconia Posted June 25, 2011 Share Posted June 25, 2011 LOVE the sound of our boxer engines!!! Thanks for the vids Link to comment Share on other sites More sharing options...
BIGAL8899 Posted June 25, 2011 Share Posted June 25, 2011 yes!!!!! thank u very very much.....mine sounds the same an i was wondering the same as everybody else. so if any differece in sound i should worry?correct? Link to comment Share on other sites More sharing options...
lowwill Posted September 30, 2011 Share Posted September 30, 2011 My 05 OBXT sounds alittle quieter but has a slight shimmy with the motor at idle. Rpm gauge stays around 1k. Manual shifter has alittle shake also. Link to comment Share on other sites More sharing options...
