Baddog Posted June 17, 2011 Share Posted June 17, 2011 So I noticed I have a decent sized pool of ATF under my car. I have been having a slight burning smell so this may be the cause. I am curious as to what could be leaking. From what I can see it is on the front side of the transmission. I am sure it's ATF because it is red and smells like ATF. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 17, 2011 I Donated Share Posted June 17, 2011 get it up in the air and check both the pan and the cooling lines going to the radiator. could it be power steering? most people put ATF in their power steering. could be the rack leaking -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted June 17, 2011 Author Share Posted June 17, 2011 It's coming out from right behind the jacking plate. Link to comment Share on other sites More sharing options...
Baddog Posted June 17, 2011 Author Share Posted June 17, 2011 So I looked and found out that I am leaking out of the seal in the front differential where the CV axle goes in. It is pushed back about an inch and a half. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted June 18, 2011 Share Posted June 18, 2011 thats gear oil in their where the cv goes in.. its kinda normal to have a little leak there. but not like drips... Link to comment Share on other sites More sharing options...
Baddog Posted June 18, 2011 Author Share Posted June 18, 2011 I messed it up. Its leaking/dripping. Leaving puddles under my car. Link to comment Share on other sites More sharing options...
