1astrokeit Posted June 12, 2011 Share Posted June 12, 2011 I just started having this issue when starting from a dead stop n just easing out on the clutch with a little gas the car shakes a lil and it feels like something is holding the car back. Almost like the emergency brake is up half way . I replaced the clutch about 7 months ago. It has been fine except for a few days ago. I have a clutch masters fx200 with wrx flywheel and tsk3. Any ideas? Link to comment Share on other sites More sharing options...
omnicron Posted June 12, 2011 Share Posted June 12, 2011 Maybe the e-brake is binding? Link to comment Share on other sites More sharing options...
1astrokeit Posted June 12, 2011 Author Share Posted June 12, 2011 I will check. This only happens whe n I first start off, after that it runs great Link to comment Share on other sites More sharing options...
omnicron Posted June 12, 2011 Share Posted June 12, 2011 My friends Legacy was going this and the ebrake inside the drum was not disengaging with the cables being released. I would not get the thing apart it was pressing from the inside. Link to comment Share on other sites More sharing options...
1astrokeit Posted June 13, 2011 Author Share Posted June 13, 2011 Im not getting any kind of brake smell Link to comment Share on other sites More sharing options...
Max Capacity Posted June 13, 2011 Share Posted June 13, 2011 That could be because once the speed is up a bit the shoes can't over come the movement of the drum's...? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
