Blue Posted June 7, 2011 Share Posted June 7, 2011 Anybody here running the Wagon specific STI Sport Springs (Pinks) and Koni's (in the stock strut housings) on a 2005-2009 Legacy GT Wagon? If so, are shims required for the rear in order to avoid a saggy butt? -Blue Link to comment Share on other sites More sharing options...
Max Capacity Posted June 7, 2011 Share Posted June 7, 2011 I'm no expert, but from what i've read on here, shims may be needed. The wagon has along overhang. Contact someone like Mike at AZPinstalls. He's on here somewhere. Have you posted this in the suspension forum ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
sactojesse Posted June 7, 2011 Share Posted June 7, 2011 I'm no expert, but from what i've read on here, shims may be needed. I haven't tried pinks w/ Koni's, but I don't think you'd need shims in the rear. The front pinks are rated at 15 mm (.6") drop with Bilsteins and the Bilstein/Spec B/JDM LGT tophats, but they drop considerably more (1" or so) when used with the stock USDM KYB-style tophats. Link to comment Share on other sites More sharing options...
