Hugo L. Posted May 25, 2011 Share Posted May 25, 2011 Lately I noticed there was a clunking sound coming from the front pass. side of my car upon deceleration, I could hear it when the car had reached a low speed. «tonk-tonk-tonk-tonk-tonk...» When trying to reproduce it, I noticed that if I turn left/drive straight in a parking lot, and drive slowly in circles (so there is a load on the right side + some angle on the CV joints), I hear it; at parking lot speeds, it's more like a creak. «eeaah-eeaah-eeaah-eaaah...» If you go faster, the sound blurs a bit and sounds like the «tonk-tonk» above, and when at full speed, you can't distinguish it from the road noise and all. If I turn right, it doesn't seem to do it. Wheel bearing or CV joint gone bad? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 25, 2011 Share Posted May 25, 2011 If it's only while turning that's normally a CV. Replace the whole axle. $70-80 for a new assembly. There are links here to buy new ones. I went to Advance Auto parts for mine. $80.00 If it makes a thunk noise over cracks in the driveway it end links on the swap bars. Also buy them from one of the vendors here. I went with Perrin's Solid end links. DO NOT replace them with the OEM style. Wheel bearings are a constant hummm. They are covered for 100,000 miles. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hugo L. Posted May 25, 2011 Author Share Posted May 25, 2011 My end links are new, that's not it. Is replacing the axle a big job? Link to comment Share on other sites More sharing options...
