gil_ong Posted May 18, 2011 Share Posted May 18, 2011 so i have a problem. took my TMIC off and i can't get it back on. damn. and i thought it was struggle with my bugeye WRX. problem #1 the gasket between the TMIC end tank and the pipe that goes to the TB is tron. i think i'm gonna need a new one. it's a funky one. the end tank "pipe" goes inside, then one layer of the coupler or whatever it's called, then the pipe that goes to the TB and then another layer of the rubber sleeve on the outside. secured by a clamp. anyone know what this ia called? or a part number? problem #2 for the life of me, i can't get the end of the TMIC end tank pipe to fit into the sleeve enough so i can clamp it down. any tips or tricks? finally gave up after 30 mins so i don't work myself into a frenzy and feel like kicking the damn dog that was running circles around me and the car. that and my back hurt like hell. so! any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
gil_ong Posted May 18, 2011 Author Share Posted May 18, 2011 here's as far i've gotten it to go . http://farm4.static.flickr.com/3077/5734733117_4c07ab96fb_z.jpg Link to comment Share on other sites More sharing options...
mike677 Posted May 18, 2011 Share Posted May 18, 2011 Pics of what your talking about? Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 18, 2011 Share Posted May 18, 2011 How do people have such a hard time with that hose. I had my IC off in 3 minutes when I did my heat shield install. I had the IC back on in 2 minutes. Easy as pie. Make sure it's not getting hung up anywhere. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
StoplightAssassin Posted May 18, 2011 Share Posted May 18, 2011 #2. wd40, carb cleaner, liquid wrench. etc Link to comment Share on other sites More sharing options...
gil_ong Posted May 18, 2011 Author Share Posted May 18, 2011 Pics of what your talking about? posted How do people have such a hard time with that hose. I had my IC off in 3 minutes when I did my heat shield install. I had the IC back on in 2 minutes. Easy as pie. Make sure it's not getting hung up anywhere. i will cut you! not hung up. #2. wd40, carb cleaner, liquid wrench. etc tried PB blaster and silicone spray. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 19, 2011 Share Posted May 19, 2011 Then you are doing something wrong. When I did it, I installed the TMIC coupler first, then rotated the intercooler down to the turbo. Worked like a charm, and I was done in just a few minutes. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
ShatzGT2 Posted May 19, 2011 Share Posted May 19, 2011 then you are doing something wrong. When i did it, i installed the tmic coupler first, then rotated the intercooler down to the turbo. Worked like a charm, and i was done in just a few minutes. +1 Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 i'm gonna buy a new collar/gasket tomorrow and give it another go. bac, that's what i did. or tried to do. i even removed the driver side TMIC support to give me more room to maneuver. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 19, 2011 I Donated Share Posted May 19, 2011 Just wiggle it back and forth a bunch. Big movements with the TMIC, not small ones, will get it back on. Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 i'm pinching j255c's image from this thread. http://legacygt.com/forums/showthread.php/throttle-body-intercooler-hose-24111.html http://legacygt.com/forums/attachment.php?attachmentid=12705&d=1134614769 i'm looking for the boot on the right side. http://farm3.static.flickr.com/2302/5736520325_0b58011767_z.jpg Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 i'm beginning to wonder if this boot is an "add on." but it can't be since it's on j255's as well. looked on opposedforces and didn't see anything. called the dealer and the parts guy (who i know) doesn't see it either. http://opposedforces.com/parts/legacy/us_b13/type_38/intake_and_supply_system_turbocharger/intercooler/illustration_1/ http://opposedforces.com/parts/legacy/us_b13/type_38/intake_and_supply_system_turbocharger/intake_manifold/illustration_1/ Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 so the only thing i can think of is that the boot comes with the air intake duct. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted May 19, 2011 Share Posted May 19, 2011 get your spray lube, and spray the shit out of the IC outlet on all sides. I have no trouble getting my perrin IC in this way. if I don't use lube, it doesn't slide in the hole at all, no matter how hard I try. it will just pop out Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 i used my silicone spray yesterday. hoping a beer and some "alone time" will help when i get home today. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted May 19, 2011 Share Posted May 19, 2011 Boot is or should be lightly glued to the coupler. Or so was my experience. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 thanks climber. i might consider do it if it's still a PITA today. but i'm also hesitant to remove the pipe from the TB. Link to comment Share on other sites More sharing options...
gil_ong Posted May 19, 2011 Author Share Posted May 19, 2011 i just tried again. still no luck. i thought i almost got it. wasn't a perfect fit, but it was damn close. so i tightened the clamps and the boot started slipping off the intake duct. Link to comment Share on other sites More sharing options...
joeblow Posted May 22, 2011 Share Posted May 22, 2011 Just wait til you upgrade to a larger TMIC. I have to manhandle mine to get it to fit. To not be a troll and actually add input, the "boot" is unimportant. The instructions for most aftermarket top mounts include removing those in order to gain clearance. As long as the band clamp is tightened down enough to do its job, you should have a problem leaving the "boot" off. The hose is probably not lined up properly. It probably got twisted when you removed the TMIC. I would loosen up the band clamp on the TB side and rotate the hose. It should follow the contour of the stuff around it. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
gil_ong Posted May 22, 2011 Author Share Posted May 22, 2011 thanks, i'll give it a go tomorrow. good thing i'll never get a larger TMIC. Link to comment Share on other sites More sharing options...
iNVAR Posted May 22, 2011 Share Posted May 22, 2011 When I got my AVO TMIC, it told me to remove the boot. I took it off, and popped the hose onto the new TMIC without lube or anything at all. Just slid it on easily, and tightened the clamp. Link to comment Share on other sites More sharing options...
dr_sharp Posted May 23, 2011 Share Posted May 23, 2011 I think you just haven't gotten mad enough at it yet. In my experience, there's always a point where you're just too pissed to care anymore then things all of the sudden go together after you apply HULK force. lol Link to comment Share on other sites More sharing options...
gil_ong Posted May 23, 2011 Author Share Posted May 23, 2011 yeah. i try my best to bot do that. really don't have a reason to do so now since i car pool with my wife. even though, if she keeps up with the rubbish i had to put up with this morning.......... Link to comment Share on other sites More sharing options...
Brosephine Posted May 23, 2011 Share Posted May 23, 2011 key is to put the tb hose side in first, then wiggle it, and shake your ass, then wiggle some more, then nod your head and make drum sounds with your lips. It all goes together, and make sure the tb hose isn't upsidedown, I've heard of dealers installing them the wrong way, there should be a flat spot in the tube at the bottom... Link to comment Share on other sites More sharing options...
CasopoliS Posted May 23, 2011 Share Posted May 23, 2011 The "boot" is there from the factory. Perhaps you have the orientation of the TB coupler wrong? This is a 3 minute job. clamp the coupler to the TB with the white dot facing directly upward (there is a white dot somewhere on the TB coupler)put the tmic in place and insert it into the other end of the coupler, just let it rest on the turbo right now, just work on getting it clamped to the TB couplerwiggle the tmic until it lines up with the turbo and also the holding bracket. Bolt it up. Done The key is to clamp up the TB side first. Once you are done with that, it should be relatively close on the turbo side. Generally it needs pulled towards the turbo for the holes to line up. I always put the turbo bolts in loosely, then get the TMIC bracket installed to help hold the TMIC which puts less stress on the turbo bolts. Then I tighten everything down, using low torque on the turbo bolts. Link to comment Share on other sites More sharing options...
