ATB Posted May 9, 2011 Share Posted May 9, 2011 I have an 05 LGT wagon with 64k miles. The turbo has not blown (yet) but based on threads here, I am getting worried. For the past 1k miles or so, I have noticed a hot / burning oil smell after the car has been driven for a long distance. I took it to the dealer and was told it was a leaking CV boot. Twice this weekend while driving in the Catskill mountains in NY, I had cases where after a using high boost for a few min accelerating up a slope, I smelled a hot/burning smell. Today it was so bad, I feared something under the hood might actually have been on fire. I immediately went very light on the throttle and pulled over as soon as i could. I opened the hood and nothing was obviously wrong, but the smell (now reduced) was coming from the turbo area. I fear my turbo may be getting starved of oil and either burning what gets to it or the area around it in the engine bay. Am I nuts? Is this some other problem? If the turbo is going I would ideally like to catch it or at least replace the turbo before it takes more of the engine with it. Bought the car used with 11k miles on it. Since I have owned it, it has gotten a synthetic change every 4k miles or less. It is the wife's car and generally gets driven very softly. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 9, 2011 Mega Users Share Posted May 9, 2011 It's probably grease from the cv boot leaking onto the downpipe. When you get on boost, the DP temp will be higher causing the smell. It could also be an oil leak dripping on the header. Link to comment Share on other sites More sharing options...
csaari Posted May 9, 2011 Share Posted May 9, 2011 My car is in the shop right now for a torn CV joint boot. I had been having the burning oil smell on and off for about a week. When I finally checked it out, I immediately noticed grease all over the downpipe, and then I looked at the CV joint, and the boot was torn completely open. Link to comment Share on other sites More sharing options...
doccrowley Posted May 9, 2011 Share Posted May 9, 2011 had severe oil burning smell after a dealer oil change. Took it back, CV boot had torn and thrown grease all over Down Pipe. DP burning passenger side CV boot is very common on our cars. Smell and smoke will rise upward right by turbo and make you worry. Find an independent subie shop to replace the CV boot. Dealer did mine for approx 170. My mechanic now wants 85 to replace a boot. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 9, 2011 Share Posted May 9, 2011 We replace about 5-7 passenger side front axles on LGT's per month at our shop. The heat from the DP/Cat tends to cause the inner boot to get brittle and eventually crack. -mike Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 9, 2011 Share Posted May 9, 2011 We replace about 5-7 passenger side front axles on LGT's per month at our shop. The heat from the DP/Cat tends to cause the inner boot to get brittle and eventually crack. -mike Which is a good reason to wrap the downpipe, and run heat shields. I'm going to wrap my TXS downpipe, and probably fabricate a heat shield as well. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
AZP Installs Posted May 9, 2011 Share Posted May 9, 2011 Yeah agreed. We replace em on stock cars. I think its part of the design flaw of the dp proximity. Mike Link to comment Share on other sites More sharing options...
ATB Posted May 9, 2011 Author Share Posted May 9, 2011 Makes sense but as per my post, the dealer (supposedly) fixed a torn CV boot when I had it in a few weeks ago. Guess it need to go somewhere else for a 2nd opinion. Link to comment Share on other sites More sharing options...
robinlsb Posted May 9, 2011 Share Posted May 9, 2011 Double check the banjo bolt??? "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 9, 2011 Mega Users Share Posted May 9, 2011 When the boot fails, it sprays grease everywhere. I had a burning rubber smell for a month after my boot failed. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 9, 2011 Share Posted May 9, 2011 Yup, it likely may be residual grease. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | T-1 Certified Amsoil Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
