dante2699yahoo.com Posted May 7, 2011 Share Posted May 7, 2011 Halos in. Now, I'm tryin to wire my halos to the parking light. Do anyone know which wires color for the left and right is the power and the ground? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 7, 2011 Share Posted May 7, 2011 what do the wires for the halos look like? ive done what youre doing, what color are yours? http://i161.photobucket.com/albums/t232/wakeboardingguy/0_16.jpg Link to comment Share on other sites More sharing options...
camroncamera Posted May 7, 2011 Share Posted May 7, 2011 EDIT: I see you mean the halo rings, not city light. ************** I ran a single jumper wire from the city light (I think what you are calling a parking light) to the turn indicator/parking bulb. The USDM turn indicator bulb has three wires. IIRC, they are Black = Ground Red = Parking Light (on continuously) Striped = Turn Indicator (flashing) Tap into the solid red wire to make the city light illuminate continuously when the parking lights are on. Link to comment Share on other sites More sharing options...
subikid90 Posted May 7, 2011 Share Posted May 7, 2011 I cut the parking light off and wired it directly to my city light, so amber is only turn signals -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 7, 2011 Author Share Posted May 7, 2011 Thanks. I figured that out. lol. Ok @ Zues. Did you tap the rings directly into the parking lights? Or did it have relays? Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 7, 2011 Author Share Posted May 7, 2011 Here is my problem....... Driver side bright. And Passenger side dim as hell. What could be causin this. And another problem. When I turn the headlights on. My highs are on as well, but at half power. What could be causin that as well. I followed the diagram. But I see its happen to others. So how you fix that as well. lol. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 7, 2011 Share Posted May 7, 2011 where are the ballasts for the halos for each light? the passenger side is dim more than likely because the ballast is too far away from the rings themselves, i tried splicing to lengthen the distance between ring and ballast but it was increasingly dimmer the farther i got.. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 8, 2011 Author Share Posted May 8, 2011 Yeah. I will have to buy another ballast or Just order other set. Link to comment Share on other sites More sharing options...
