m3ph Posted May 2, 2011 Share Posted May 2, 2011 I was messing with the car yesterday. I was looking underneath the dashboard and i saw this green wire that was disconnected. I didn't know what it was so i plugged it in. This is supposable the Subaru diagnostic wire. After plugging it in i noticed the check engine light was flashing. So i ran to auto-zone and pulled the codes of the car. can some one help me figure out where the problem is and how to fix it. Here are the codes. p0130 p0136 p0500 p1100 p1101 p1120 p1121 p1540 I read online that that p0500 and p1540 causes the car to go in limp mode. I sort of noticed that the car runs sluggish. What happens to out legacy when it goes in limp mode. Dose it get less power? I also read something about the speedometer that might be causing the VSS 1&2 errors. Where should i start looking? Also the car dose not start right way sometimes it takes a few clicks to start, and i know the starter code is in the list. Should i just replace it? Thanks guys for your help. BTW the car is 1997 LGT MT 171000 miles, Just had the HG replaced 600 miles ago. I don't know if the codes came before that. I bought the car with the bad motor. Link to comment Share on other sites More sharing options...
johnegg Posted May 2, 2011 Share Posted May 2, 2011 dis-connect the green connector and you will be right back to where you started, no CELs. the green connectors are NOT supposed to be connected. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 2, 2011 I Donated Share Posted May 2, 2011 Was your check engine light on before you connected the green connector? Thats not suppose to be connected. Unplug is and if your check engine light wasn't on before, you should be fine as soon as you unplug it. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
m3ph Posted May 2, 2011 Author Share Posted May 2, 2011 Why would the codes just show up after i plugged it in? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 2, 2011 I Donated Share Posted May 2, 2011 dunno. that green thing is tucked away under the dash so people don't mess with it lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
