babybluelgt Posted May 1, 2011 Share Posted May 1, 2011 For some reason my tail lights stopped working. It keeps blowing the fuse for it. The brake lights, reverse lights, and turn signals still work though. Also the interior lights that light up the radio/hvac controls stopped working, but all the buttons still work. The only lighting/electrical mods I've done are LED front turn signals and 100w fog lights. My first guess was the fogs were drawing too much, but wouldn't they stop working as well then? I'm guessing there is a short somewhere, but i have no idea where to start. Has anyone else had this problem or have any suggestions on a cause or where to start? Link to comment Share on other sites More sharing options...
laz Posted May 1, 2011 Share Posted May 1, 2011 If I had to guess I would say take off the LED lights and see what happens. X --- Link to comment Share on other sites More sharing options...
johnAWD Posted May 1, 2011 Share Posted May 1, 2011 First step in debugging electrical issues: undo what you've just done & test. Link to comment Share on other sites More sharing options...
babybluelgt Posted May 1, 2011 Author Share Posted May 1, 2011 thanks, thats what I was thinking and it just hit me that the turn signals are part of the running lights. hopefully i can keep the LEDs because the car looks sooo good with them and the cleared corners Link to comment Share on other sites More sharing options...
pre-dent Posted May 1, 2011 Share Posted May 1, 2011 LEDS without resistors are going to blow a fuse. That is most likely your problem. Check the fuse box under the dash and get rid of the LEDs unless you plan on doing it the right way. Link to comment Share on other sites More sharing options...
babybluelgt Posted May 2, 2011 Author Share Posted May 2, 2011 Ok, so I took out the LEDs and put in a fresh fuse. The fuse no longer blows, but the lights still don't work. Anymore suggestions?? I'm really not looking forward to trying to find a short. Link to comment Share on other sites More sharing options...
A_Tang Posted July 8, 2014 Share Posted July 8, 2014 LEDS without resistors are going to blow a fuse. That is most likely your problem. Check the fuse box under the dash and get rid of the LEDs unless you plan on doing it the right way. Sorry to revive an old post, but I've got the same issue as babybluelgt. Can you explain why LEDs without resistors would blow fuses? I understand that without resistors or a digital flasher you would get the fast blink problem, but why would it blow fuses if LEDs run with less amperage? Link to comment Share on other sites More sharing options...
FknBoss Posted July 8, 2014 Share Posted July 8, 2014 Leds have very little to no resistance. The current moves to fast thru the fuse and causes it to blow. Leds mimic a short. Link to comment Share on other sites More sharing options...
FknBoss Posted July 8, 2014 Share Posted July 8, 2014 Some leds now a days have built in resistors so it doesn't do this. Back in 11 they didnt they were pretty new. Now if the resistance is correct they usually just blink fast. But will need a resistor to get it to blink normal. Link to comment Share on other sites More sharing options...
