lilbrudder Posted April 26, 2011 Share Posted April 26, 2011 So my cruise control has not worked since I bought my spec B with 40K on it. The CC will not engage at any speed in any gear. I had the ECU reflashed, did not fix. I had the ECU replaced, did not fix. I have data logged the Neutral safety switch, seems to work fine. The control lever/switch on the sterring wheel seems to work...."CRUISE" light comes on when the end button is pushed, but it will not "SET" when lever pushed down. Any one have the steering wheel lever go bad? or CC unit? If anyone can gime me some tips on trouble shooting this I would really appreciate it, I have a drive down the ALCAN in a couple weeks...2000mile without CC may kill me...so you could save my life! Link to comment Share on other sites More sharing options...
nightspeed98 Posted April 26, 2011 Share Posted April 26, 2011 From what I understand, there are various switches that cancel cc. Including the clutch, brake, shifter and speed. Also, stupid a it sounds, fuses and fusible links. Not sure our cars use the last one Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 26, 2011 Share Posted April 26, 2011 Check the clutch switch. If the upper switch is closed, CC won't work. It could either be stuck closed, or intentionally closed from some half-assed remote start install attempt. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
lilbrudder Posted May 9, 2011 Author Share Posted May 9, 2011 Checked the clutch switch, not the problem... Link to comment Share on other sites More sharing options...
goneskiian Posted May 9, 2011 Share Posted May 9, 2011 I wonder if my issue is related? I just did a road trip and the cruise control kept turning itself off. Link to comment Share on other sites More sharing options...
whitehe9 Posted June 11, 2011 Share Posted June 11, 2011 my cruise hasn't worked for over 2 years. It actually works up to about 65mph most of the time, rarely over 70 and never over about 75. it pisses me off now enough to fix it. strangely enough, it worked for a month after they replaced the 65000 mile blown OEM turbo, then quit working again. Again it worked for a short time after I changed the spark plugs. Not sure if these are coincidence? Anyway I'm eager to hear how to fix it because my mechanic didn't want to drive over 70 to check it out. HELP!!! Link to comment Share on other sites More sharing options...
GTTuner Posted June 11, 2011 Share Posted June 11, 2011 I knoe you said you logged the neutral switch but I owuld take it out and check it with an ohm meter. I have seen switches look ok on a log but when you ohm it out is has funky resistance values. Take it out and test it after checking what everyone else described above. Link to comment Share on other sites More sharing options...
lilbrudder Posted June 11, 2011 Author Share Posted June 11, 2011 That's a valid point, and worth a try. I will have to research the easiest way to access the NSS. Link to comment Share on other sites More sharing options...
lilbrudder Posted June 11, 2011 Author Share Posted June 11, 2011 I have been doing a bit of searching for trouble shooting diagrams for the CC system, but no luck yet. As far as I can tell there is no Cruise control module like the older subies, it seems like it is all done through the ECU with a relay or two. can anyone verify if this is accurate? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 13, 2011 Share Posted June 13, 2011 FWIW my 05 would drop out of cruise on a down hill run. The fix was to remove the NSS grind down the washer and re-install. worked fine for a while. Then it started doing it again, I had to remove the NSS grind down the washer again and re-install, it's worked fine for years. IDK may be it's something like that ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
pflo Posted June 14, 2011 Share Posted June 14, 2011 Has the vehicle's ECU been reflashed with a Cobb Accessport? My cruise hasn't worked since I unmarried a V1 AP. There are some threads around that may help. Link to comment Share on other sites More sharing options...
slimjim2 Posted November 5, 2011 Share Posted November 5, 2011 Grinding down the "copper" washer under the neutral position switch worked like a charm for me. I would guess it is about 1/3 thinner than it started. Hint: Grind it evenly as it does seal in transmission fluid. Link to comment Share on other sites More sharing options...
lilbrudder Posted November 5, 2011 Author Share Posted November 5, 2011 I may have to try this, do you have any pics of the washer/location? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 13, 2011 Share Posted November 13, 2011 The neutral safety switch is the high switch on the side of the tranny, the lower one is the back up lights. Pull the connector, I used a adjustable wrench to get he sensor out. The sensor has a crush washer on it, take it off and grind it thinner. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kirk83 Posted December 15, 2011 Share Posted December 15, 2011 Hey guys , i have a 2005 legacy GT Limited. my cruise control work around town fine if u driving 20 miles or less. If im driving over 50 miles to another state it works for about 12 miles then it cuts off by itself. The only way to get it working is to turn off the car for a few minutes while getting gas. it works for another 12 miles then chips out again..... Helpppppp Link to comment Share on other sites More sharing options...
lilbrudder Posted December 15, 2011 Author Share Posted December 15, 2011 Yours sounds pretty classically like the washer problem, see the post above yours to fix it. Link to comment Share on other sites More sharing options...
lilbrudder Posted July 14, 2012 Author Share Posted July 14, 2012 Follow up for the fix!!! So we have winners....nightspeed and bac5.2 were right it was the clutch switch. I finally found the diagnostic diagram and figured out that although the lower clutch switch(there are two) appeared to be working(made a clicking noise) it was not sending the proper voltage to the ECU. For anyone interested in the diagnostic approach to the CC system: Voltage should be checked at the ECU, under the FRONT PASSENGERS feet, you must pull back the carpet and remove a metal plate to access it. check voltage of the following: 1.main power supply 2.command switch during CANCEL, SET, & RESUME 3.brake switch 4.stop light switch 5.main switch(at end of CC command switch) 6.ignition switch 7.clutch switch 8.neutral position switch(MT) 9.neutral signal(AT) That is the basics, pin placement is variable depending on MMY so you will have to find the schematics for your car. Thanks for everyones input and I hope this helps someone else, if you need more info just post and I will check my diagrams. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted July 22, 2012 Share Posted July 22, 2012 Grinding down the "copper" washer under the neutral position switch worked like a charm for me. I would guess it is about 1/3 thinner than it started. Hint: Grind it evenly as it does seal in transmission fluid. I finally had to to do this over the weekend as my cruise had totally quit. I went to NAPA and took the factory washer with me. Found a matching copper washer much more thin. The factory one measured with a dial caliper is .079 The one from NAPA was .030 which looked pretty thin. Installed it yesterday and my cruise works like a champ. Monitoring it with the AP shows it turning off and on real sold whereas before it was flickering on and off on its own. Link to comment Share on other sites More sharing options...
MoD_Scotty Posted September 30, 2013 Share Posted September 30, 2013 Thread resurrection! The cruise control on my GT (manual) started "cancel"ing itself tonight. I'm going to try the washer thing. Anyone tried a new neutral switch? I imagine its pricey, but it seems like a more permanent solution to the issue. Link to comment Share on other sites More sharing options...
lilbrudder Posted September 30, 2013 Author Share Posted September 30, 2013 You should try to adjust the switch ...or take it apart and clean it. It is a simple switch once you get it apart. Link to comment Share on other sites More sharing options...
KCwagon Posted October 4, 2013 Share Posted October 4, 2013 Thread resurrection! The cruise control on my GT (manual) started "cancel"ing itself tonight. I'm going to try the washer thing. Anyone tried a new neutral switch? I imagine its pricey, but it seems like a more permanent solution to the issue. The washer on the NSS is pretty thick. I would try going to NAPA or another Parts store and find a thinner washer of the same diameter. A buddy of mine did that with his and it worked great. Link to comment Share on other sites More sharing options...
MoD_Scotty Posted November 2, 2013 Share Posted November 2, 2013 $27 for a new NSS from the dealer. Swapped it out in 5min when I had the car on a lift yesterday. Seems to work great now. Link to comment Share on other sites More sharing options...
kirk83 Posted April 14, 2014 Share Posted April 14, 2014 The neutral switch is bad on the gearbox. . Link to comment Share on other sites More sharing options...
LegUp Posted August 17, 2016 Share Posted August 17, 2016 Resurrect! You guys that had a switch issue, when cruise turned itself off, would cruise light flash afterwords? Link to comment Share on other sites More sharing options...
