Legacy GT Driving Sim Project
i mainly made this topic to help keep me going on this project as i know you guys will be pushing me to finish and pointing out flaws that im sure to make and if you want even help research how the interface connect to a computer.
So with that i present the first pics of the building. Yes already.
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/205634_10150152195389877_712759876_6796826_3958891_n.jpg
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/217200_10150152194764877_712759876_6796811_2654909_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/206923_10150152194814877_712759876_6796814_1631937_n.jpg
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc6/206959_10150152194874877_712759876_6796818_4203497_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/215004_10150152194909877_712759876_6796821_3390381_n.jpg
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc6/217205_10150152194934877_712759876_6796822_876666_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/207421_10150152194964877_712759876_6796823_5212184_n.jpg
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc6/215266_10150152194984877_712759876_6796824_3546999_n.jpg
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/217510_10150152194999877_712759876_6796825_5099218_n.jpg
fresh pics of todays progress. tomorrow is finishing up the panels to cover the box and then it all comes apart for painting. then if i have time i start the massive amount of wire labeling..
going though the pdf version of the fsm right now.
to power everything i have a two computer power supply units. i need the 12 volt rail power. one puts out 13 amps and the other only 8.
13 amps X 12 volts( at least, even under load) =156 watts of power. does anyone know if that would be enough to run the radio, the climate control, and all the backlighting. im thinking it will be close.
  • I Donated
nope you can't like through email lol. Use photobucket.com or imageshack.com or something like that
If you give us all your gmail login info, we will be able to see it haha. but the rest of us get 404 errors because we are logged into our email - and the file doesn't exist in our email accounts.
-broknindarkagain
My Current Project - Click Here
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
todays progress. was raining and was busy off somewhere else.
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/206883_10150152923539877_712759876_6806313_6235922_n.jpg
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/215726_10150152923594877_712759876_6806314_2525786_n.jpg
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc6/206767_10150152923654877_712759876_6806315_255847_n.jpg
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/207563_10150152923744877_712759876_6806316_4368231_n.jpg
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc6/217650_10150152923834877_712759876_6806318_4361473_n.jpg
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/206275_10150152923864877_712759876_6806319_3703108_n.jpg
Illl have to work more on it next weekend unless i for some reason have time after school to work on it.
i cant decide if i wanna use the steering from a gaming wheel or the car.
if i use the cars setup i can use the cars key to turn on and off things in the order they do in a real car.
such hard choices. haha
you can make the radio work and everything maybe even tie your home ac to the vents. I would use the wheel from the car. also a 5 speed gear box that looks oem for the dash I would also set the radio system up so I could use it without the game with a sub and amp combo.
yea. i need to go the junk yard to pull the center consul from a 5spd outback and the shifter stuff. i ahve no idea what it all looks like or how im gonna hook that all up. and get the gauge cluster out of it and set it to 000,000, plus my needles in that one are all mess up from tacking them off so much cause of my old after market gauge faces.
i will try very hard to use the stock steering colum but it mounts to the crossmember that goes from a pillar to a pillar, and the dash mounted to that too. wiring should be fun though. :spin:
i wanna use it so bad so i can use the ignition on it for starting all the stuff.
i need to get a new deck. i think the one in it is broke casue when it folds down it never stays down. it just keeps folding up and down. so i think ill pull the oem one up of the outback too. unless i can find my old oem one. or buy a new deck for my new car and use the oem one out of that.
for the vents. i may get to that. but i just though out the stock piping for the vents. i think ill use computer fans for the vents. and run the power though the dial on the climate control unit.
