CT05Legacy Posted March 29, 2011 Share Posted March 29, 2011 Anyone running an '05 LGT with catless uppipe? any issues with emissions? I'm replacing my turbo and thinking of going with a catless up at the same time, but worried about passing emissions without it. Link to comment Share on other sites More sharing options...
JaeGT Posted March 29, 2011 Share Posted March 29, 2011 08 come catless for their up pipe from the factory so I think you'll be ok. And going catless up on your 05 may be healthier for your turbo. Search for stories about catted up pipes Link to comment Share on other sites More sharing options...
GTStage2 Posted March 29, 2011 Share Posted March 29, 2011 I am running a catless uppipe, catless down pipe and a hi-flow cat in the mid and have never had a problem passing inspection. Link to comment Share on other sites More sharing options...
AFBeefcake Posted March 29, 2011 Share Posted March 29, 2011 As long as your CE is off you should not have any isues. My wifes 05 LGT passed CT emissions with no cats. We did have one high flow cat added in now just incase. Link to comment Share on other sites More sharing options...
2005hondakilla Posted March 29, 2011 Share Posted March 29, 2011 no cats and passed. ive put cats in though due to smell Link to comment Share on other sites More sharing options...
CT05Legacy Posted March 29, 2011 Author Share Posted March 29, 2011 no cats and passed. ive put cats in though due to smell removing just the cat in the uppipe caused a bad smell? Or were you completely catless throughout the entire exhaust? Link to comment Share on other sites More sharing options...
2005hondakilla Posted March 29, 2011 Share Posted March 29, 2011 complete catless. you will need the uppipe o2 sensor disabled by a tuner or resistor or you will throw a light. Subaru should have never put the catted uppipe in. They were an awful emissions idea that was soon changed by them for many reasons. Many vf40's fall victim to the catted up because it breaks up and will clog and completely throw the stock ecu off and sufficate the turbo exhaust side and pieces shot in the turbo causing turbine damage. moral is get the catted one out lol. Its a b**** to do but well worth it. if your doing a new turbo i highly recommend it as well because i had to take mine out to get the up-pipe in. I have a catless up and invidia catted downpipe and the smell is extremely minor. Link to comment Share on other sites More sharing options...
CT05Legacy Posted March 30, 2011 Author Share Posted March 30, 2011 complete catless. you will need the uppipe o2 sensor disabled by a tuner or resistor or you will throw a light. Subaru should have never put the catted uppipe in. They were an awful emissions idea that was soon changed by them for many reasons. Many vf40's fall victim to the catted up because it breaks up and will clog and completely throw the stock ecu off and sufficate the turbo exhaust side and pieces shot in the turbo causing turbine damage. moral is get the catted one out lol. Its a b**** to do but well worth it. if your doing a new turbo i highly recommend it as well because i had to take mine out to get the up-pipe in. I have a catless up and invidia catted downpipe and the smell is extremely minor. Thanks for the help. isn't the o2 sensor in the RH exhaust manifold, upstream of the cat in the uppipe? only sensor in the uppipe is the exhaust temp sensor. so installing a catless uppipe will still throwoff the o2 sensor in the exhaust manifold? any recommendations on uppipes? i know there are alot of aftermarket options, and I really don't know what differentiates them. Link to comment Share on other sites More sharing options...
2005hondakilla Posted March 30, 2011 Share Posted March 30, 2011 aah yes that is correct sir thats a egt sensor. i have a greddy uppipe Link to comment Share on other sites More sharing options...
demo243 Posted April 2, 2011 Share Posted April 2, 2011 Yea catless UP is definitely the way to go. Little bit quicker turbo spool... slight bit of turbo noise if you pay attention... and much much safer for your turbo. No problems with emissions either, I was worried about this earlier (there is a post a little further back) and I am running catless UP, catted DP, and Greddy catback... they just plug the car in and check for codes. Took me 5 minutes and no trouble... except the guy stalled my car pulling it out of the spot I was parked in... was not happy about that one. Link to comment Share on other sites More sharing options...
jaxx4k Posted April 2, 2011 Share Posted April 2, 2011 catless/up-dp-cbe. no problems here.. but i'm starting to hate the fume, so i might go back catted.. Link to comment Share on other sites More sharing options...
Verwilderd Posted April 10, 2011 Share Posted April 10, 2011 ? any recommendations on uppipes? i know there are alot of aftermarket options, and I really don't know what differentiates them. Most pipes will be the same. If you want to go the cheapest route possible, take your stocker off and gut it.....if you aren't comfortable with that, you can find stock 08+ ones on here and nasioc for around $50 or so all day long. I wouldn't waste the money buying an aftermarket one as they actually aren't as well built and don't have the heatshielding as the stocker....unless you are wanting to add an ewg later on and are wanting a pipe for that, stay with the stocker one (just make sure it's gutted). If you use yours, just make sure the sensor hole is plugged. As for the cel, have your car tuned (which you will want anyway) and it'll go away. Link to comment Share on other sites More sharing options...
